Thread: New start
Hi Nr1madman,
Where in Sweden are you located? I have a UC300USB resting on the top of my PC, gathering dust. I only use it occasionally to test things, or to run Mach3 without the CNC, and of course, it is also a spare unit, since the base (motherboard) is the same as for the UC300ETH, so I want to keep it, but you can borrow that and see if it helps.
29-05-2018 #2
Sounds awesome :D
I'm located in Trosa just south of Stockholm.
You?
Before I'm going on a borrowing roadtrip I'm going to try with a new computer and if that don't work I will try running mach3 (a friend has a license) .
I'm not hoping that mach3 will solve this as I rather like uccnc :)
If all fails I will gladly take you up on your offer!
01-06-2018 #3
I am located just outside Lund, so it is a long road trip... cheaper if Postnord does the trip. :) Anyway, only the motherboard can be used for test since the UCCNC license is based on the main CPU board. This means that the USB connector and the handling of communication and processing can't be swapped out.
NEW MEMBER: We all need to start somewhere!
By Realtime in forum New Member IntroductionsReplies: 0Last Post: 16-05-2017, 08:43 PM -
NEW MEMBER: A new start for me.......
By Nthkentman in forum New Member IntroductionsReplies: 4Last Post: 23-08-2014, 10:50 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
