Thread: New start
15-03-2018 #221
They actually started making plugins for mach3 but never got past the beta phase it was working but the last posts on the mach forum are 5 years old so one would assume it's been abandoned. Given they had it working it seems a shame they didn't finish the work and bring it to market.
Fusion is still free
https://knowledge.autodesk.com/suppo...usion-360.html
It's annoying that the controllers don't support both linuxcnc and Mach3 it seems it's a case of supporting one or the other.
I totally get the linuxcnc thing you have to be a sadist to go this route but I've been a casual linux user since 2006 for 6 years I never ran anything else but when I got into cad I had to go back to windows. Also I grew up with a dos prompt so linuxcnc isn't quite so scary.
Now I have a couple of machines running linux and a couple running windows.Last edited by Desertboy; 15-03-2018 at 08:52 PM.
15-03-2018 #222
This is a link to the current website - still looks to be free for "enthusiast" (home/hobby) use.
15-03-2018 #223
Thanks to both of you :D
I must have clicked wrong to get to the educational license...
15-03-2018 #224
15-03-2018 #225
Im actually starting to get some good results in solidworks for CAD.
Tried fusion before and will give it another try.. tried rhino aswell but that was hard!
For cam Im really liking estlcam. Played some with cambam but it's not working out like I plan ;)
Uccnc will be another thing! CAD and cam I can do indoor with the wife and semi communicate with her while learning. Uccnc is in the shed with the machine so any time spent "learning" will be time away from wife and kids. That's gonna be something to make up for :D
16-03-2018 #226http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
17-03-2018 #227
Just wanted to ask, since it might be your schematic.
Why does the enable signal go through two relays? The coil of the enable relay is driven through master relay.. Why not take the enable signal straight to the master relay? ( I've done this temporarily now)
17-03-2018 #228
In all honesty I don't know. It's not something I would normaly do so maybe the OP added it. You certainly will be fine running it thru master relay.
The reason I think it's mine is because there are parts of it like the master relay which I drew and recognise. if you notice there are 6 contacts but it states 4PDT. However there are bits I don't recognise and wouldn't use, like that enable relay, so maybe I've helped someone with basic setup which I often do then they have added to it.?
17-03-2018 #229
17-03-2018 #230To be honest I never use the enable on steppers unless I want to keep holding torque on motors. For instance in Limit situation
Originally Posted by Nr1madman;
Limits are not an emergency situation so no reason to kill power to the drives but sometimes, like with a heavy Z axis, you will want to keep holding torque.
In this case I'd use the Enable in series with Limits.
Otherwise, I just don't use it because of not much point with steppers.Last edited by JAZZCNC; 17-03-2018 at 11:56 AM.
NEW MEMBER: We all need to start somewhere!
By Realtime in forum New Member IntroductionsReplies: 0Last Post: 16-05-2017, 08:43 PM -
NEW MEMBER: A new start for me.......
By Nthkentman in forum New Member IntroductionsReplies: 4Last Post: 23-08-2014, 10:50 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
