Thread: New start
Page 29 of 41 FirstFirst ... 19272829303139 ... LastLast
  1. #281
    Quote Originally Posted by driftspin View Post
    Hey Nr1madman,
    Congrats on the first cut.
    Grtz Bert.
    Thanks :D
    I hope to say the same to you soon!
  2. #282
    2amperes is good but how thin are the wires?
  3. #283
    It's 0.5mm2 wires. So they should be more than fine. They just feel thin/flimsy.
    I'm used to 1.5mm2 wires ;)
  4. #284
    You are just fine,according to this :
  5. #285
    Okey.. Had another false e-stop today while surfacing a spoilboard :(
    But that is something I can chase, try, tinker with and scream at.
    Have another problem, when homing my dual motor axis something have happened.
    Uccnc seemed to release the slave axis (has to to square the gantry) when I paired them again I can't home?
    And if I restart the computer I can home again but just once?
    I can still home z and y how many times I want..
    Suggestions? :)
  6. #286
    So I thought :)
  7. The Following User Says Thank You to Nr1madman For This Useful Post:
  8. #287
    What do you mean when say "When I paired them again" .? The software should be taking care of the homing seamlessly in the background and you shouldn't have to be doing anything.!
  9. #288
    Well.. I messed up a "home x" session with an e -stop :D
    After that uccnc said slave a axis to x axis but only x motor moved.
    So I chose slave none, saved, then slaved a axis again.
    Now they work while running programs and jogging but "home x" does not work as it should..
    My bad but how do I fix it? ;)
  10. #289
    Ok well if changing the settings isn't working then I'd suggest you re-install UCCNC. Maybe got a corrupted file or plug-in.?
  11. #290
    Good morning!
    Lovely day today, gonna tidy up some wires and see if I get better results :D
    Any feeds and speeds tip for surfacing plywood with a 12mm 4 flute endmill hss.
    Not really a suitable tool but the biggest I got right now :)
    Have figured out that 1 or 2 flute would be better!
There are currently 14 users browsing this thread. (0 members and 14 guests)
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
