Thread: New start
Page 31 of 41 FirstFirst ... 212930313233 ... LastLast
  1. #301
    Yeah, I come from more of a machining background. I was thinking of 1/4", 3/8", and 1/2". But, I bet a good 1/4" coated 3-flute without too long a cutting helix could do 8K. Hopefully, I 'll get to see in next month or so. My 2.2KW spindle should be here in couple weeks.
    Thanks,
    Wallace
  2. #302
    Quote Originally Posted by wallyblackburn View Post
    Thanks,
    Wallace
    I cut Ali regularly with 8mm 3 flute Uncoated Carbide cutters at 12K-15K and 6mm 15-18K. Very rarely do I drop below 10K with any cutter when cutting ali.
    The 2.2Kw WC spindles don't really have enough torque to cut ali at lower speeds.
  4. #303
    Alright, since you are all discussing :D
    How about a v-bit 60degrees 2 flute.
    What's a starting point in mdf and in oak?
    The only suggestions I've found are for shapeoko type machines and I dont think they are all that accurate for me since they refer to dialnumbers on dewalt routers for speedsetting and something like 500mm feed (20 ipm)
    I must be able to go faster? And DOC ? Is it even that relevant when engraving? :)
  5. #304
    5000rpm / 3000mm/min for a 10mm HSS V-bit in hard wood.
    7000rpm / 4800mm/min for a 10mm carbide v-bit in hard wood.
    Both are 2-flute tools, just estimates as it depends on how deep you go etc with an angled cutter.
    DOC is always important, all factors are important - get them too wrong and it goodbye cutter :)
  6. #305
    Well.. I expressed myself badly.. :)
    What I ment was that I will engrave with max 5mm (mostly about 3mm) DOC so to my thinking it should work in one pass?
    As the spindle is (as you put it) useless under 8000rpm I should be aiming for 5000mm/min? As starting point?
    Haven't even tried jogging at those speeds yet :D
    Still playing and calibrating but 4000mm/min went fine so I will give it a try next time I get a chance!
  7. #306
    I would try at whatever setting you and your machine are comfortable with to start ;)
    V-bit are awkward for feed/speed as the diameter is not fixed so the speed will only ever be correct for one part of the tool. Wood is very forgiving and people do this every day so we know it can work. If using router bits, they sometimes come with recommended settings on the pack and routers are generally high speed so these tools would suit the spindle well.
    Its all a matter of breaking tools and learning - I shudder to recall how many new carbide bits i smashed when learning the settings, its a sharp lesson when you put a new £15 tool in and it only cuts 5mm before going in the bin :)
  8. #307
    Oooh.. sounds promising. With no local suppliers for new bits I might err on the cautious side ;)
  9. #308
    Try to buy some Chinese bits ,a dozen of them in different size there is no way to avoid braking some of them, was In procedure of eliminate some router bits before I sell my previous CNC,lol.
    No matter what the calculators says about speed and feed it also has to to with your machine's settings as Davek already said. So better to brake some cheap bits than to see to cry for the expensive ones....
    I can't recall how many times I stamp a bit in a wood and Plexi because I forgot to zero Z axis!!! ,:-P
  10. #309
    This was my plan. But since Sweden has new import charges Im searching for a eu supplier. Shipped from Germany would be nice and fast :)
  11. #310
    Been playing some more :D
    Look at this video, what might be causing this weird motion?
    To fast motion for set kernel speed or just funky g code?
    Have cut circles with constant speed so this was a first :)
    https://m.youtube.com/watch?v=hlvP9uEJP8g
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
