Thread: New start
Page 1 of 41 12311 ... LastLast
    Oi fellows!
    Its time for me to finally start my own buildlog.
    Will update as soon as something happens
    Best regards
    Mr madman
    So.. restarted the frame!
    My old welder died on me and from then to now all the steel got used for various purposes :)
    This is where I'm at now with the new fra me :)
    Wow, in the space of 5 minutes,
    "Its time for me to finally start my own buildlog.
    Will update as soon as something happens "
    (5 minutes later)
    "My old welder died on me and from then to now all the steel got used for various purposes :)"
    Hehe Im mostly surfing the forums via my phone and for some reason I can't create threads on this forum from the phone. Only reply.. Had to borrow my sons computer to create the first post :)
    Continued with the frame today
    Encountered the first mayor problem.
    I've had the Z axis plates milled from steel. Because of some sloppy cadwork (had my calculations wrong) the Z axis rails had theire holes in the wrong place :(
    Have drilled the hole's larger to get it together so will have to use nuts and washers to fasten the rails.
    Have a feeling I will have to order a new plate :)
  6. The Following User Says Thank You to Nr1madman For This Useful Post:
  7. #6
    The underside of the frame have gotten some paint and the epoxy experiment has begun :D
    I framed the x rails with wood and sealed it to the steel with latex. Then I glued strips of masonit to get the right width of epoxy channel. 40mm wide for 20mm wide rails and 50mm wide bridge at the middle of the rails. Have just brushed on a small layer of epoxy to really get it tight with no leaks. Big pour will happen tonight or tomorrow!
  8. #7
    You make it look easy!
    What are the dimensions for this machine?
  9. #8
    Nickhofen thank you for your kind words!
    The machine is 1200x960mm and work area around 900x600.. Im hoping for 150mm Z movement but I think I bought the wrong cablechain :D
  10. #9
    You are my man, I try to build a cnc with similar dimensions but my cad abilities are below zero, sub zero, submarine etc....I will watch closely.
    I have read yours and others guys builds in here several times and have take some good info, thanks for sharing,then and now!!!
    What rails and screws are you going to use,stepper or rervo, can you give more info about your build ?
  11. #10
    Good luck with the pour, keep bubbles out and maintain a reasonable temperature.
    I think it would have been a good idea to include some diagonal bracing on the frame; http://www.mycncuk.com/threads/6565-...2425#post52425
There are currently 14 users browsing this thread. (0 members and 14 guests)
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
