Thread: New start
14-03-2018 #201
14-03-2018 #202
It will!!!
Why you are not satisfied with the UC300 usb version?
Here at post#158 Jazzcnc explains why the usb version is better than the parallel one.
http://www.mycncuk.com/threads/10911...655#post100655
14-03-2018 #203
The usb version is more vulnerable to signal loss and interference than the Ethernet version.
Both are better than paralellport.
But I'm sure the usb version will work fine for my needs.. as I'm only running 40cm of shielded cable mounted to the motherboard it should work flawless :D
Now I have to research what other BOBs or relays I want/need for running extra equipment such as lights and dustvac and such :)
The Following User Says Thank You to Nr1madman For This Useful Post:
14-03-2018 #204
UC have a USB or ethernet solution, Jazz was comparing using a PC with PP for step generation. UC cards are step generators. It gets confusing because like me nr1madman is using a cheap PP BOB to connect to the steppers, switches etc.
but the connection to the PP BOB is running a lot faster than if it was a PC PP. A few people have warned that using that cheap board will limit upper performance but I was told you will be able to run at least 50khz per axis with that cheap board connected to a step generator if you need more you need a better breakout board. For my Mesa card it's £100 for the better BOB so I'm happy to use my existing BOB for now and 50khz is actually a lot depending how you set microstepping.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
The Following User Says Thank You to Desertboy For This Useful Post:
14-03-2018 #205
14-03-2018 #206http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
14-03-2018 #207
14-03-2018 #208
15-03-2018 #209
Alright.. now Im really really tired of wires :D
Got the pc working and installed uccnc sucessfully!! Makes me want to scream in joy!
As Ive said before Im following a schematic I found on the forum.
But in this schematic the limitswitches power a relay and this enables a signal to the bob.
Shouldnt the limitswitches be connected with the estop circuit and stop the main relay from latching?
That way the power would be cut if a limit is breached?
Otherwise the axis that hits a limit might continue if there is software malfunction?
15-03-2018 #210
Do you have soft limits as well? It's all debatable but hitting the limits say while jogging should not (in my opinion) be an E-Stop as it is not an emergency
NEW MEMBER: We all need to start somewhere!
By Realtime in forum New Member IntroductionsReplies: 0Last Post: 16-05-2017, 08:43 PM -
NEW MEMBER: A new start for me.......
By Nthkentman in forum New Member IntroductionsReplies: 4Last Post: 23-08-2014, 10:50 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
