Thread: New start
    My simple bob handles 24v so thats fine.. you say input and that makes me think I did right :D
    Im going to use two inputs for homing (one for x y z and one for a which is slaved )
    Limits are for another input.
    Probe and e stop makes it full :)
    Have to get one more bob!
    I think we need to define home and limit. Home is a reference point, limit means "any further and something bad will happen". If you want to home each axis, you'll have to use an input for each axis. Limits can be connected to same input because, if any are tripped it is an error situation and you just want all to stop ASAP. You can then determine what the problem is.
    Does that make sense?
    Regards,
    Wallace
    Quote Originally Posted by wallyblackburn View Post
    Regards,
    Wallace
    Yes, total sense if you home all axis at the same time. You can actually home one axis at a time and back of the sensor so you can sense the next "home"
    When / if I buy another bob and get more inputs I can home all at the same time :)
    Not sure how you have it setup but you have 5 input pins this is how I am setting mine up. Z and Y1 sharing a pin, then X & Y2 on their own pin which leaves a pin for touch sensor and a pin for estop. Then set it up to home Z first then home X&Y at the same time. This is good for me as the Z is then always at the highest point before it moves the X/Y so clearing any brackets I have strung across the bed.
    I have Y1 and Y2 as I have 2 microswitches and 2 motors on the Y axis. So when it homes it can adjust itself square. This was a bitch to do in linuxcnc lol and I have to do it again when I set the Mesa up but shouldn't be so bad the 2nd time.
    I'd connect limits to the estop if you have separate ones after all you should never use them unless something has gone wrong but you can also wire all the limits to share the touch setter.
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
