Thread: New start
    Got some more work done
    nice to see it's moving smoothly! did you sort out your screw binding issue?
  3. The Following User Says Thank You to Zeeflyboy For This Useful Post:
    Thanks ;)
    Yeah the screw is working fine now. I found out that one of the screwholes in the ballnut bracket is a little off. Since I have to remake the Z dropplate anyway the easy fix was oversizing the mating hole for the crooked screw. 7mm instead of 6 was a winner ;)
    Now I have to secure the dropplate or it will slide to far down!
    Still waiting for the htd belts to arrive and I'm hoping the motor will hold it even powered down. How do you guys solve this issue? A block under z when the machine is powered off?
  5. #4
    All my machines have always held in position switched off.
    If your Z is particularly heavy or you are using a longer pitch ballscrew I guess you need to think about either a counter balance of some sort (which will help your stepper out if the Z is particularly heavy) or some sort of lockout system to hold it up I guess.
  6. #5
    Good to hear ;)
    I have 1610 screw for my Z. Ordered 1605 but got wrong pitch delivered. Full refund from Mr China man so I have compensated with pulley ratio to the motor.
    I think my Z plate is several kgs in weight. 15mm thick steel around 160x 300mm big..
    Will remake it in aluminium at a later date ;)
    Really hope it will hold without dropping, have to see when the spindle bracket arrives!
There are currently 20 users browsing this thread. (0 members and 20 guests)
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
