    Chaz's Avatar
    I need to do a set of 4.3 and 5.3 mm holes, at least 20mm deep.
    I can drill these but will need to buy specific drill bits which may never get used again (around £15 each, carbide).
    I could interpolate, problem is that a 3 or 4mm endmill typically only has a flute length of around 10mm max. There would likely be long reach endmills, will have to source.
    Accuracy needs to be fairly good, how would you do this?
  2. The Following User Says Thank You to Chaz For This Useful Post:
  1. just how deep does a water trough need to be?
    By nobby in forum Plasma Table Machines
    Last Post: 09-07-2017, 04:27 PM
  2. foam cnc carver- deep z axis - 4x4 bed
    By marbles in forum Hotwire Cutting Machines
    Last Post: 17-05-2016, 09:20 AM
  3. What tooling to drill lots of 10mm holes 45mm deep?
    By AlanMJackson in forum Tool & Tooling Technology
    Last Post: 13-01-2014, 08:53 PM
  4. How deep can i cut MDF?
    By MrWiz73 in forum Machine Discussion
    Last Post: 24-08-2011, 10:38 PM
