To be clear I'm not planning to build this any time soon. When the new machine is finished I'll run with the spindle direct and see how it goes. Significant stiffness increase should allow me to do much more than current machine.
But the indirect drive version of the spindle does indeed use the R8/TTS combo with tools changed manually via the draw bar. But I basically threw this together to make sure when the time comes I had space to do the upgrade. Not worked out pulley reduction and the speeds I might want or gone deeply into bearing size and max rpm or looked at any optimisation of parts.
I'll see if I can output a few of the key parts (bearings housing spindle drawbar) to give you a start point if you are ok with it on that basis. I don't know if this will work but has the right features. You need to think about hardening and grinding of the taper and possibly bearing journals unless you want to make a demo part first
I can do iges format which most cad programmes can read. Away from machine so give me a day or so.
If you use it and develop and build something please post it up as you'll probably get there before me ! Thanks
Ps with a bit of work a PDB can be added to give quick changes. I won't go this far but ATC is then possible if you want to add that as well
19-07-2017 #2
21-07-2017 #3
I see at least some one is making lower RPM spindle in the standard 80mm mounts compatible with standard VFD's
https://www.youtube.com/watch?v=T-F_xZHEWDU
I'm surprised the Chinese aren't already all over it.Last edited by Desertboy; 21-07-2017 at 12:18 PM.
21-07-2017 #4
21-07-2017 #5
24-07-2017 #6
Chaz,
For info in case you missed it, TTS/R8 new thread posted here:
http://www.mycncuk.com/threads/11138...3218#post93218
24-07-2017 #8Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
RFQ: Large bed CNC Mild Steel (500 x 500 x 50)
By Jono in forum Projects, Jobs & RequestsReplies: 0Last Post: 03-04-2017, 05:05 PM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
eBay: 300W 12V-48V DC High speed air cooled spindle motor for engraving milling
By Swarfing in forum Items On eBay UKReplies: 0Last Post: 16-06-2013, 01:33 PM -
High speed spindle for Sieg X1
By ecat in forum Spindles & Drive MotorsReplies: 8Last Post: 29-03-2012, 08:56 AM -
High speed spindle
By leadinglights in forum Tool & Tooling TechnologyReplies: 0Last Post: 27-04-2010, 09:23 PM
