    GND's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 16-07-2024 Has been a member for 9-10 years. Has a total post count of 85. Received thanks 3 times, giving thanks to others 11 times.
    I'm looking to switch my Kress 1050FME for a 2.2kW water cooled spindle, for use on my evolving CNC router build. I am looking to reduce the screaming noise, allow a better selection of cutters to be used, as well as improving runout. I understand this is the way to go.
    I suspect that many of you have such spindles, so I wondered where forum members have successfully sourced them from? A few people I know have bought them from CNC4YOU, which feels like a safe choice. However I suspect these are just imported from China and marked up by a significant amount. Looking on Aliexpress and eBay there is loads of choice, and I'm wary of picking up a dud. It's still a not insignificant investment even from China!
    Any guidance or past experiences would therefore be much appreciated!
    Graeme
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    This is where I have bought a few https://www.ebay.co.uk/i/26062601854...6856138&crdt=0
    Be careful as there are two flavours of the vfd this is the better one check the front panel out.
    This is the bad one http://www.ebay.co.uk/itm/2-2KW-WATE...3D260626018545
    GND's Avatar
    Many thanks Clive - just what I was looking for. Good info on the VFD options too - that clone one is pretty similar until you know what you're looking for!
    Just as a point of note - did the delivery actually come from Germany? And if not, did you have to pay import fees and so on?
    Graeme
  5. #4
    Quote Originally Posted by GND View Post
    Graeme
    It came in a few days so I assume from Germany. No fees. But be aware that you will have to change the parameters in the VFD and it depends how you want to control it check the number of poles to match the motor etc
  7. #5
    I bought this one
    http://www.ebay.co.uk/itm/2-2KW-CNC-...19.m1438.l2649
    Not sure the difference but looks as if I have the good VFD, came in 3 days from Germany.
    When I got it was some bumpf about having 4 bearings but I take that with a pinch of salt lol if it works for 2 years I got my money's worth ;)
  8. The Following User Says Thank You to Desertboy For This Useful Post:
  9. #6
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 4 Weeks Ago Has been a member for 7-8 years. Has a total post count of 985. Received thanks 118 times, giving thanks to others 52 times.
    I've just found this thread from last year. Unfortunately the two links above now show exactly the same photograph.
    Kit
  10. #7
    Kit
    https://www.ebay.co.uk/itm/2-2KW-WAT...8AAOSw-W5Us1mz
    This is the "good" vfd
  11. #8
    Kitwn's Avatar
    Thanks Desertboy.
    I'm assuming I'm not going to get the best price by having a unit from China sent to Australia via Germany. Is the key here to look for a genuine (though how do you tell?) Huan Yang VFD?
    Regards
    Kit
  12. #9
    Thanks Desertboy.
    Regards
    Kit
    Look carefully at the picture of the front panel to see the difference and also below the pic. you will see that you can scroll through the various pics of it and find the one of the inside it should have a double row of terminals with a relay to one side.
    You can get them direct from China.
  13. #10
    https://www.aliexpress.com/store/gro...=price_asc&g=y
    Make sure it's set for AUS delivery at the top to get accurate prices.
    I use alixpress all the time never had an issue.
  1. High Speed Spindle - Drilling & Mild Steel
    By Chaz in forum Spindles & Drive Motors
    Last Post: 29-07-2017, 07:09 AM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Replies: 0
    Last Post: 16-06-2013, 01:33 PM
  4. High speed spindle for Sieg X1
    By ecat in forum Spindles & Drive Motors
    Last Post: 29-03-2012, 08:56 AM
  5. High speed spindle
    By leadinglights in forum Tool & Tooling Technology
    Last Post: 27-04-2010, 09:23 PM
