Thread: servo cables?
I have a temp controlled soldering station and the crimps as well so I'm good to go.
Not sure those crimps will work on the IDC ribbon connectors I have bought?
Do you have the lcd display for setting them up Boyan?
22-07-2017 #2
IDC ribbon connectors I normally use a vice. I have used pliers and mole grips in the past, but it's better if you can get the whole connector to crimp square and at once, with control over how quickly the connector closes.
Boyan, those crimping pliers won't cover that many connectors. I've got a set with 12 interchangeable jaws, and it still doesn't cover everything I need it to. I spent most of my life dealing with vehicle electrics, and some terminals just won't work without the correct crimping jaws. And although soldering will work, as I said in my previous post, you risk the wire fatiguing and breaking, especially if it's done poorly.
Unless the connector is designed to be soldered, I would never personally solder it.
Best case scenario if a crimp/solder joint/wire fails, is things stop working. Worst case is the drive and/or motor gets destroyed.
Ultimately how well any method will work, will depend on the final implementation. A cable that is well secured with minimal vibration, doesn't have the same risk of failure as something being constantly vibrated and flexed.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
23-07-2017 #3
Thanks MC. the connector has two options on the press plate (no idea if that what it called but it the plate that pushes the wire in to the v on the pin) one is complete so looks like the wires have to come out the ends and the other has a slot down the middle which seems the best option for the cables but not sure how best to crimp it.
The motor and drive is for a very small lathe spindle (emco unimat pc) so vibration and movement will be minimal.
23-07-2017 #4
Have you got a link/photo of the connectors?
If they're not your typical ribbon cable connector, they may need a punch down tool. If that's the case, something narrow and blunt, like the blunt edge of a Stanley knife blade will usually work.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
23-07-2017 #5
I put a link in post 3 but not very clear. http://www.ebay.co.uk/itm/3M-10150-6...c=1&rmvSB=true
23-07-2017 #6
Those could be tricky.
If you're using ribbon cable, I'd use something blunt to press it in enough to hold it before fully crimping it in a vice.
Even if you're using non-ribbon cable (you'll have to ensure it's the correct size/strand size of wire), I'd push them in first, otherwise it'll be pretty much impossible to crimp everything at once.
However, I think personally I'd go for the solder version of those connectors, but be warned, they'll be fiddly to solder. You have to solder the inside row of connectors, otherwise the outside row means you can't get the solder iron to the inside rows.
Alternatively if you want to avoid crimping and soldering, you could buy some ready made breakout boards, but they're not cheap for micro d connectors.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
23-07-2017 #7
The servo connectors i soldered. Now i had burned some wires the first time with my ugly soldering gun. Thats why i recommended a good one. But i guess once you spend a day trying to figure things out and at the end of the day you find the problem is because of your soldering skills, next time you quickly learn to make it properly.
i think my servos use similar or same connector and a soldered it carefully / the second time/ so now all is fine. With good gun, solder and flux,and correct size heat shrinking its not a problem. I extra potted them i believe
using my hot glue gun. I dont like leaving things to chance
The crimp pliers i bought for general use and as i don't use them professionally, till now i haven't found a scenario where they will not serve. Their main purpose was to crimp heated carbon wire to normal heat resistant wire
Replacement cables
By Paul B in forum Chinese MachinesReplies: 6Last Post: 25-04-2017, 11:24 AM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
FOR SALE: Pack of Omron servo drivers + cables
By albertoro in forum Items For SaleReplies: 0Last Post: 25-01-2015, 12:19 PM -
Which cables to shield?
By andy586 in forum General ElectronicsReplies: 0Last Post: 02-07-2014, 04:33 PM -
USB repeater cables
By Web Goblin in forum General DiscussionReplies: 0Last Post: 21-05-2011, 12:36 PM
