Thread: servo cables?
    Lives in East Lothian, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Those could be tricky.
    If you're using ribbon cable, I'd use something blunt to press it in enough to hold it before fully crimping it in a vice.
    Even if you're using non-ribbon cable (you'll have to ensure it's the correct size/strand size of wire), I'd push them in first, otherwise it'll be pretty much impossible to crimp everything at once.
    However, I think personally I'd go for the solder version of those connectors, but be warned, they'll be fiddly to solder. You have to solder the inside row of connectors, otherwise the outside row means you can't get the solder iron to the inside rows.
    Alternatively if you want to avoid crimping and soldering, you could buy some ready made breakout boards, but they're not cheap for micro d connectors.
    The servo connectors i soldered. Now i had burned some wires the first time with my ugly soldering gun. Thats why i recommended a good one. But i guess once you spend a day trying to figure things out and at the end of the day you find the problem is because of your soldering skills, next time you quickly learn to make it properly.
    i think my servos use similar or same connector and a soldered it carefully / the second time/ so now all is fine. With good gun, solder and flux,and correct size heat shrinking its not a problem. I extra potted them i believe using my hot glue gun. I dont like leaving things to chance
    The crimp pliers i bought for general use and as i don't use them professionally, till now i haven't found a scenario where they will not serve. Their main purpose was to crimp heated carbon wire to normal heat resistant wire
    Thanks MC and Boyan
    Wishing I had got the solder version now. Did you connect all the wires or just the ones you need?
    Do you have the user LCD for programming? I don't so not sure how to set it up.
    Thanks MC and Boyan
    I made longer 3 of the wires and soldered all the connectors inside. As main problem here is i live 200m from sea and typical humidity is 85% so even crimped connections will fail sometimes.
    When i connected 2 cables together and used heat shrink tubing on each core, then i cut in half a proper size silicone tube. Fitted the connection there and potted it with hot glue gun.
    You dont need LCD. You need a computer, serial port and special serial cable, check manual of what variety it was, as i remember i needed different variety for the Galil controller.
    Samsung servo software is free and self explanatory. For the Galil servo control software you have to pay some 2xx euro additionally for example hence, that's why i said before buying servos check if servo software is free like the Samsung one.
  5. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  1. Replacement cables
    By Paul B in forum Chinese Machines
    Last Post: 25-04-2017, 11:24 AM
  2. eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
    By dazza in forum Items On eBay UK
    Last Post: 29-01-2015, 08:55 AM
  3. FOR SALE: Pack of Omron servo drivers + cables
    By albertoro in forum Items For Sale
    Last Post: 25-01-2015, 12:19 PM
  4. Which cables to shield?
    By andy586 in forum General Electronics
    Last Post: 02-07-2014, 04:33 PM
  5. USB repeater cables
    By Web Goblin in forum General Discussion
    Last Post: 21-05-2011, 12:36 PM
