Thread: servo cables?
26-07-2017 #13
I made longer 3 of the wires and soldered all the connectors inside. As main problem here is i live 200m from sea and typical humidity is 85% so even crimped connections will fail sometimes.
When i connected 2 cables together and used heat shrink tubing on each core, then i cut in half a proper size silicone tube. Fitted the connection there and potted it with hot glue gun.
You dont need LCD. You need a computer, serial port and special serial cable, check manual of what variety it was, as i remember i needed different variety for the Galil controller.
Samsung servo software is free and self explanatory. For the Galil servo control software you have to pay some 2xx euro additionally for example hence, that's why i said before buying servos check if servo software is free like the Samsung one.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
Replacement cables
By Paul B in forum Chinese MachinesReplies: 6Last Post: 25-04-2017, 11:24 AM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
FOR SALE: Pack of Omron servo drivers + cables
By albertoro in forum Items For SaleReplies: 0Last Post: 25-01-2015, 12:19 PM -
Which cables to shield?
By andy586 in forum General ElectronicsReplies: 0Last Post: 02-07-2014, 04:33 PM -
USB repeater cables
By Web Goblin in forum General DiscussionReplies: 0Last Post: 21-05-2011, 12:36 PM
