    Some of the cheap ones are not even plastic, but thin plywood.
    Nothing wrong with a I3 Graber ;)
    I bought the frame for one because they look good especially when varnished.
    They print very well mate has had one a few years working many hours day and still produces excellent prints.
    most grabers are 6mm ply but if you have a router working you can easily cut a 12mm version with minor alterations in cad.
    When you start worrying too much about rigidity in the printer then you need to ditch the shit 8mm smooth rod lol and go hiwin route. But for home printer stupid overkill.
    Nearly all Prusa I3 based builds I've come across print well it's a good design there probably better stuff kicking around now but Prusa I3 printers are certainly not a bad choice.
    I've seen Acrylic, aluminium & ply builds and the box frame works just as well made with a table saw lol.
    Understanding the engineering and physics involved will show the elegance of the Prusa design, this is that the 8mm unsupported rods are not loaded dynamically the way they would be in a router or mill, the carriage acceleration loads are transferred by the drive belts, motors and motor mounts to the frame with the rails simply supporting carriage weight.
    Failure to understand this might lead to over engineering the rails and under engineering the frame when it is the frame which supplies the required rigidity for this style of machine, if you sensibly move to a tube feed system with the reel off the machine the only significant loads experienced by the 6mm Aluminium plate upper frame are in the + & - X travel directions where a planar frame performs extremely well indeed.
    - Nick
    - Nick
    I bought the Wanhao 4DS because of the steel frame, everything else is Makerbot, which has been cloned a lot, so it must have some plus points. The filament reels are on the frame, tube fed to the extruders. The machine has a heated base, which I have a borosilicate plate on. I only print in ABS and on glass I find a thin wash of ABS solution in DMK (acetone ) or MEK (methyl ethyl ketone) gives me good adhesion and easy separation when the bed cools. The other thing it has is a hood to maintain the temperature in the enclosure, which reduces (but not always eliminates) corner lifting. There was mention of a £259 Makerbot clone, and if this has a steel frame, I would consider it a good buy, if I were looking for a 3D printer.
    I haven't seen many Hiwin railed machines, probably for a good reason
    Cheers,
    Rob
    Thanks for all the advice, starting to get an idea of what I need. certainly lots of choice.
    Is there any advantage of a 24v system? I'm assuming lower current so less stress on the heater and faster stepper motors?
    Thanks again for all the input
    I have no doubt that it can be made to work, especially for printing toys, but I was referring to the thin simple designs. The one you show is really large and is more like a CNC router than a 3D printer, at least as far as the base and the beam is concerned. Also those rods look more rigid, something like 12mm (1/2") in diameter, not just 8mm. Then again, it depends on what you want to use it for. Personally I see no reason for using wood or anything similar, but I know some people disagree.
    I think it must be perspective because it's 8mm smooth rod, standard prusa build size.
    I have the same printer it's not particularly big I had a mendel and just bought the ply frame and swapped the parts over.
    Was a massive upgrade from the original mendel lol.
    This was the mendel
    One of the early FDM 3d printers for the home
    Original prusa would have been the kill with Hiwin bearings and sturdier bed. I dont believe square supported bearings are overkill for a printer, i believe they are a must for a machine that moves non stop. My Prusa growlingly agrees from the garage. My wife will tell you that too.
There are currently 19 users browsing this thread. (0 members and 19 guests)
  1. Who is Denford 3D Printer?
    By g20hz in forum Denford 3D Printers
    Last Post: 25-09-2016, 10:33 AM
  2. A3 printer plotter
    By gatesy in forum Machine Discussion
    Last Post: 21-12-2015, 04:19 PM
  3. New toy, Afinia 3D printer
    By Robin Hewitt in forum 3D Printing Machines
    Last Post: 05-07-2014, 11:18 AM
  4. eBay: 3d Printer project!
    By andrewbond in forum Items On eBay UK
    Last Post: 11-05-2013, 08:07 PM
  5. robuster 3d printer
    By wilfy in forum 3D Printing Machines
    Last Post: 06-04-2013, 11:51 PM
