Thread: looking for a good 3d printer
25-07-2017 #31
25-07-2017 #32Any idea how much to import it though? not available yet either.Agreed, for that money, its not worth the time to design, buy, build and test IMHO.
That one is about £1k, are the clones as good?I'd recommend a prusa www.prusa3d.com
I have the previous to the last model and works like a charm. With the new one they have won best printer of the year and looks like a really good printer on a budge
25-07-2017 #33
Speak to AndrewMawson on here, he imported one.
25-07-2017 #34
I'm currently using PLA (and some ABS for tougher small parts) on my (£275) Pusa i3 clone kit, I'm in the process of modifying for Nylon and for larger ABS parts as I have product designs for parts which require the better engineering plastics with higher glass transition temperatures and better durability than PLA.
25-07-2017 #35
Hows this one if I go the Purusa route http://factory3d.co.uk/
26-07-2017 #36You think that's too expensive? You're not a Model Engineer are you? :D
26-07-2017 #37
or else there are these? http://www.ebay.co.uk/itm/CTC-3D-Pri...3D321930591168
or http://www.ebay.co.uk/itm/3D-printer...AAAOSw5dNWtIzULast edited by Ross77; 26-07-2017 at 12:43 AM.
26-07-2017 #38
This Prusa is crazy cheap I'd just buy this if I were you.
http://www.ebay.co.uk/itm/2017-Upgra...3D272622069677
Add auto levelling for £2http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
26-07-2017 #39
I like the look of the Wanahao.
I'd avoid plastic framed printers like the plague, Aluminium or Steel construction at least means you have a good base for a rebuild or upgrade project at some future point.
Nozzles and Throats which aren't commonly available as generic spares are a bad idea as are machines not running the most popular open-source firmware versions.
Printers with the hot end and nozzle very close to the extruder drive may well prove problematic should you wish to print one of the more flexible filaments,
26-07-2017 #40
There are currently 22 users browsing this thread. (0 members and 22 guests)
Who is Denford 3D Printer?
By g20hz in forum Denford 3D PrintersReplies: 1Last Post: 25-09-2016, 10:33 AM -
A3 printer plotter
By gatesy in forum Machine DiscussionReplies: 4Last Post: 21-12-2015, 04:19 PM -
New toy, Afinia 3D printer
By Robin Hewitt in forum 3D Printing MachinesReplies: 34Last Post: 05-07-2014, 11:18 AM -
eBay: 3d Printer project!
By andrewbond in forum Items On eBay UKReplies: 8Last Post: 11-05-2013, 08:07 PM -
robuster 3d printer
By wilfy in forum 3D Printing MachinesReplies: 8Last Post: 06-04-2013, 11:51 PM
