Thread: looking for a good 3d printer
13-08-2017 #111
Too bad... never the less, at that price I'd expect that something needs to be fixed. Glad you managed to fix those small and simple things. Levelling issues are not difficult to fix but depending on the results you expect and the instruments you have to help you, can take time. Anyway, regardless if it is a CNC or a 3D printer, I think that spending time on levelling is beneficial in the long terms.
Not good. On the other hand, 1mm variation should be easy to reduce considerably. If you have an instrument to measure than you could see if the problem is mechanical or electrical. The mechanical variation takes some time to remove or reduce, but normally should not be too difficult.
What do you mean is the issue with the bowden extruder? The printer I am planning to build is planned to have bowden type of extruder, so I'd be interested if there is an issue I did not think about.
13-08-2017 #112
14-08-2017 #113
I found PLA a lot easier to print with than ABS I only recently changed my hot end to an E3d clone so can now print Nylon, etc. The only issue with PLA is it's absorbs water so make sure you store in with silica gel and if it has absorbed moisture an hour in the oven at 80c will sort it out.
I bought 10kg's of ABS when I first bought my printer so I make it work lol but my life would have ben much easier if I had bought 10kg of PLA instead ;)
I find ABS is strong than PLA but there's not a lot in it.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
14-08-2017 #114
Nylon can absorb up to 20% of it's weight in water and can need 1 to 4 hours at 80C to dry a full reel to the core, PLA at 80C for 1 to 4 hours will yield a nice bit of modern art but no useful filament ;-)
Print a mount for your phone in PLA and leave it on the dash in a hot car on a sunny day, then tell me that :D
I'm interested in making functional plastic components and while PLA is OK for a few bits it's properties limit it's usefulness in any applications which require greater permanence.
The Following User Says Thank You to magicniner For This Useful Post:
14-08-2017 #115
I forgot the heat thing, I print everything in ABS apart from the first prints I did so never noticed it lol.
If you want to make injection mold strength parts maybe consider Nylon or Polyurethane casting especially if you want produce a lot of one part, you can use a router or 3d printer to make you master molds.
I definitely want to have a go at casting with polyurethane and also aluminium casting but need to make a furnace first. Vacuum former is the next project but cnc style lol.Last edited by Desertboy; 14-08-2017 at 09:16 AM.
14-08-2017 #116
Bowden can be trickier to get the retraction settings dialled in properly, and rules out using flexible filaments as well.
You guys should certainly look at PETG filaments, as easy to print as PLA but as strong as ABS, doesn't absorb moisture either; some types can be stringy but good retraction settings handle that. I have been using "Real Filaments" (Check amazon) and they have been working very well for me, £15 - £20 a spool depending on colour.
Alex
The Following 2 Users Say Thank You to AlexDoran For This Useful Post:
14-08-2017 #117
15-08-2017 #118Its always a risk buying secondhand but yes it was cheap enough. Having said that I've only replaced a few screws, oiled it and changed a few setting and the print quality is much better. (mainly slowed it down and dropped the hot end temp 15 degrees) At least in happy with it now. Still using the PLA that came with it so hopefully it will get better with better filments.Too bad... never the less, at that price I'd expect that something needs to be fixed
I was looking at the e3d aero which is more controllable and can be used for all materials, I think the main issue is that for this machine it is propriety so not easy to change. its really slow on the warm up which is bugging me already.What do you mean is the issue with the bowden extruder? The printer I am planning to build is planned to have bowden type of extruder, so I'd be interested if there is an issue I did not think about.
Having done some quick prototyping tonight I can definitely see the potential so may look at up grading all the electrics, The machine is rock solid so I tthink it will be a good base which will save me a lot of time.
Might even get the lathe finished this year... :0)
15-08-2017 #119
I agree, I'm experimenting with a roll of PETG (coincidentally from real filaments!)
I have found it pretty easy to print with, although it can sometimes have small stringy artifacts, but these are easy to scrape off.
It is definately tougher than PLA, but i couldn't quantify by how much.
I think it will be my "go to" filament when strength is a factor, otherwise PLA . I haven't tried ABS yet as I've heard it's smelly and I'm enough trouble as it is!!
Pic of 16mm tube motor mount for my upcoming X8 copter printed in PETG
ASA is another good option, it's basically got all the properties of ABS but significantly less warp, less odour when printing and better UV resistance. I've tried formfutura's ApolloX with pretty nice results once I added a fan at 30-40%
I've also been having very nice results with formfutura TitanX again with the fan. Basically a modified ABS that seems to have very minimal shrinkage and warping.
Carbonfil is still by some significant margin the most impressive filament I've used in terms of making accurate structural parts with very high strength and dimensional accuracy. Its still expensive and a pain though, so still looking for my ultimate filaments... Edge (PETG type material), Apollo X (ASA) and Titan X (modified ABS) are about as close to ideal as I have yet found.Last edited by Zeeflyboy; 18-08-2017 at 12:02 AM.
The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
There are currently 25 users browsing this thread. (0 members and 25 guests)
Who is Denford 3D Printer?
By g20hz in forum Denford 3D PrintersReplies: 1Last Post: 25-09-2016, 10:33 AM -
A3 printer plotter
By gatesy in forum Machine DiscussionReplies: 4Last Post: 21-12-2015, 04:19 PM -
New toy, Afinia 3D printer
By Robin Hewitt in forum 3D Printing MachinesReplies: 34Last Post: 05-07-2014, 11:18 AM -
eBay: 3d Printer project!
By andrewbond in forum Items On eBay UKReplies: 8Last Post: 11-05-2013, 08:07 PM -
robuster 3d printer
By wilfy in forum 3D Printing MachinesReplies: 8Last Post: 06-04-2013, 11:51 PM
