    I print onto Kapton tape or straight on to a mirror with ABS juice (Acetone and ABS dissolved together). Since I rebuilt my printer and now it's level I rarely have one that doesn't stick to the bed. At least for me 99% of sticking to bed problems were to do with the nozzle being too high or too low.
    If I got another one whatever I bought/built I would make sure the Z axis has a contactless solution for setting the Z height. Inductive probe works well as long as you have an aluminium heated bed I use an 8mm probe and it will sense the aluminium bed through the mirror glass which is nice. Optical end stops are good too and hall effect switches. I found microswitchs unreliable for the Z axis.
    Never ever use stainless for a print bed stainless has very poor heat conductivity. Tooling aluminium is the best choice for a bed because it's light and has excellent heat conductivity that's why they make heat sinks out of it. The super flat is just a bonus.
    Desertboy, so you mean that the inductive sensor will sense the aluminium table? I thought it only senses magnetic material. Also, how thick is your table?
    Yes they will but you need the 8mm one
  4. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  5. #4
    I am always wary about axial sensing with inductive sensors, after crushing one. The coil at the end is quite delicate, even though it has a plastic shield.
  6. #5
    Yes the 4mm doesn't sense through the mirror and you also need to feed it 12v so if you have ramps you will need to wire 2 resistors to drop the output to 5v otherwise you fry the Arduino.
  7. #6
    I was thinking about releasing the designs to my printer, i had planned to build and sell these, but with so many cheap units flooding the market i decided it was probably not worth it, if anyone is interested i will go to the effort of updating the BOM's and finishing the documentation.
    Cronos-FDM.uk
    Alex
  8. #7
    Inspired by this thread, and on a bit of a rush of blood, i decided to buy a Wanhao Duplicator i3 Plus.
    http://www.ebay.co.uk/itm/Wanhao-I3-...72.m2749.l2649
    It arrived yesterday :-)
    I'm a total 3d print noob, so the reasons i went for this particular one are:
    • Was mentioned as a good choice in this thread.
    • Price, £379.
    • Generally positive reviews on internet & You Tube.
    Overall I'm very impressed, for the money.
    As I had already watched quite a few YouTube guides, assembly & setup was a breeze.
    It took me about 45 mins from the box coming through the door to starting my first print. (the 'ok' hand that comes on the SD card)
    The print quality is pretty good. Again i'm more than happy with it for the money paid.
    I've printed a lens cap & gimbal mount for my camera using STL files downloaded from the internet(Thingiverse) and then used Cura to generate the G-Code
    It was all relatively straightforward & again very happy with results
    Next step is to try some of my own stuff drawn in Fusion 360.
    It's worth pointing out that I have never even seen a 3d printer 'in the flesh' before this one, so don't take my impressions as worth much. I don't have anything to compare to!
    The photo's are of my first few prints. They look better in real life than in the photos! (The white plastic doesn't seem to photograph very well)
    I'm stoked
Name:	f106349824 (Large).jpg
ID:	22444Click image for larger version.
Name:	f106388736 (Large).jpeg
ID:	22442Click image for larger version.
Name:	f106424832 (Large).jpeg
  9. The Following User Says Thank You to Greeny For This Useful Post:
  10. #8
    Nice one, Kind of wishing I had just bought one now...
  11. #9
    Swings & roundabouts i suppose
    In terms of getting going quickly and ease of use, it's a winner.
    However if building your own you will almost certainly end up with a better machine.
    For the money paid I'm very happy with it, but it's definately built with parts supplied by the lowest bidder
  1. Who is Denford 3D Printer?
    By g20hz in forum Denford 3D Printers
    Last Post: 25-09-2016, 10:33 AM
  2. A3 printer plotter
    By gatesy in forum Machine Discussion
    Last Post: 21-12-2015, 04:19 PM
  3. New toy, Afinia 3D printer
    By Robin Hewitt in forum 3D Printing Machines
    Last Post: 05-07-2014, 11:18 AM
  4. eBay: 3d Printer project!
    By andrewbond in forum Items On eBay UK
    Last Post: 11-05-2013, 08:07 PM
  5. robuster 3d printer
    By wilfy in forum 3D Printing Machines
    Last Post: 06-04-2013, 11:51 PM
