Thread: G-Code Sender
    Guys
    I have just purchased a CNC XPRO CONTROLLER V3. I'm looking for a G-Code sender for this controller. Mach3 is not compatible. I prefer something for nothing (don't we all) but would pay for the right bit of kit.
    All suggestions will be welcome.
    Mac or PC
    Tony
    I see on their website they use CamBam, well have a look at this plugin for it; http://www.cambam.co.uk/forum/index.php?topic=6482.0
    Then download a trial version here; http://www.cambam.info/downloads/
    get this version; 0.9.8.P Released 22 Sep 2015 build 0.9.5729.19316 Rev P
    It's not free but you will struggle to find anything cheaper that is anywhere near as good, it's the only CAM software I use.
    Thank-you!
    Is that a G-Code sender?
    Sorry don't have any idea, I think I have the process but not sure what software does what at the moment.
    I'm planning to use Inkscape to create the svg file and Makercam to create the G-code do I then use CamBam to send the G-code to the controller?
    Tony
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  5. The Following User Says Thank You to Ger21 For This Useful Post:
  6. #5
    CamBam does CAD and g-code, you shouldn't need any other software, you should take some time to read the CamBam thread I linked to.
  7. #6
    Ger21's Avatar
    Eddy, you should take the time to see what he has, and how it works.
    He needs something to send the g-code to his GRBL controller.
    Gerry
  8. #7
    Gerry,
    Maybe you could do the same, the plugin I linked to is called "GRBL v1.1 Machine Control and GCODE sender Plugin"
    The Plugin installs a 3rd tab in CamBam's tabpanel. Inside the tab you'll find a couple of expanders:
    Display --> Shows an LCD display with the most important, realtime, data directly from the machine
    Production --> This will be the actual GCODE sender. It's filename is integrated with CamBam's generated CGCODE file
    Jogging --> Lets you run around the machine, set it's working origin etc.
    Console --> Shows a commandline, from which you can enter and send GCODE directly to the machine and a log window for the commununication between the Plugin and the machine.
    Connection --> Lets you select a comport and connect really to the machine. It has an auto USB recognition feature
    About --> Some words about the Plugin Wink
  9. #8
    Ger21's Avatar
    LOL.
    Gerry
  10. #9
    Thanks guys,
    CamBam, although a very good piece of software a bit more than I was hoping to pay at this stage of my venture.
    I shall keep looking.
    Zapmakers grbl sender is know to brick my type of controller, which is a shame because it looks ideal.
    Tony
  1. How to 'crop' a g-code
    By paulus.v in forum CAD & CAM Software
    Last Post: 13-08-2017, 10:06 PM
  2. A little bit of G code help please!
    By njhussey in forum Programmers Corner
    Last Post: 16-11-2015, 03:36 PM
  3. Anyone got some 2.5D G-code please ?
    By dudz in forum Programmers Corner
    Last Post: 22-06-2013, 11:21 PM
  4. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  5. G Code help
    By moose007 in forum Programmers Corner
    Last Post: 22-05-2009, 11:39 AM
