Thread: G-Code Sender
I see on their website they use CamBam, well have a look at this plugin for it; http://www.cambam.co.uk/forum/index.php?topic=6482.0
Then download a trial version here; http://www.cambam.info/downloads/
get this version; 0.9.8.P Released 22 Sep 2015 build 0.9.5729.19316 Rev P
It's not free but you will struggle to find anything cheaper that is anywhere near as good, it's the only CAM software I use.Last edited by EddyCurrent; 24-07-2017 at 06:43 PM.
24-07-2017 #2
Thank-you!
Is that a G-Code sender?
Sorry don't have any idea, I think I have the process but not sure what software does what at the moment.
I'm planning to use Inkscape to create the svg file and Makercam to create the G-code do I then use CamBam to send the G-code to the controller?
Tony
24-07-2017 #3
You need to use Universal G-Code Sender or GRBL Controller 3.
https://github.com/winder/Universal-G-Code-Sender
http://zapmaker.org/projects/grbl-controller-3-0/Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
24-07-2017 #4
CamBam does CAD and g-code, you shouldn't need any other software, you should take some time to read the CamBam thread I linked to.
24-07-2017 #5
Eddy, you should take the time to see what he has, and how it works.
He needs something to send the g-code to his GRBL controller.Last edited by Ger21; 24-07-2017 at 10:56 PM.
Gerry
25-07-2017 #6
Gerry,
Maybe you could do the same, the plugin I linked to is called "GRBL v1.1 Machine Control and GCODE sender Plugin"
The Plugin installs a 3rd tab in CamBam's tabpanel. Inside the tab you'll find a couple of expanders:
Display --> Shows an LCD display with the most important, realtime, data directly from the machine
Production --> This will be the actual GCODE sender. It's filename is integrated with CamBam's generated CGCODE file
Jogging --> Lets you run around the machine, set it's working origin etc.
Console --> Shows a commandline, from which you can enter and send GCODE directly to the machine and a log window for the commununication between the Plugin and the machine.
Connection --> Lets you select a comport and connect really to the machine. It has an auto USB recognition feature
About --> Some words about the Plugin WinkSpelling mistakes are not intentional, I only seem to see them some time after I've posted
25-07-2017 #7
LOL.
Gerry
26-07-2017 #8
Thanks guys,
CamBam, although a very good piece of software a bit more than I was hoping to pay at this stage of my venture.
I shall keep looking.
Zapmakers grbl sender is know to brick my type of controller, which is a shame because it looks ideal.
Tony
How to 'crop' a g-code
By paulus.v in forum CAD & CAM SoftwareReplies: 11Last Post: 13-08-2017, 10:06 PM -
A little bit of G code help please!
By njhussey in forum Programmers CornerReplies: 19Last Post: 16-11-2015, 03:36 PM -
Anyone got some 2.5D G-code please ?
By dudz in forum Programmers CornerReplies: 5Last Post: 22-06-2013, 11:21 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
G Code help
By moose007 in forum Programmers CornerReplies: 4Last Post: 22-05-2009, 11:39 AM
