    This wont be tapped, its a through hole for a bolt.
    Ok so the .3 is putting you in the middle of standard and close fit, what I've linked to should give you what you need for a through/clearance hole of fairly good accuracy surely?
  2. The Following User Says Thank You to Lee Roberts For This Useful Post:
  3. #2
    Chaz's Avatar
    Yep, exactly. Ill order those drill bits, seems good value for money and keep for future if I ever need to do similar again.
  4. The Following User Says Thank You to Chaz For This Useful Post:
  5. #3
    Cool, if you look I think you can just buy 1 bit at a time for 99p all in or something from another seller, saves buying a box of 10.
    I'll confirm what I've got if you want and send you?
  7. #5
    Chaz's Avatar
    Thanks.
  8. #6
    Are these clearance holes for 4 and 5mm bolts?
    If so you can just drill them 4 and 5 mm because the bolts are slightly under size.
    I often drill 0.5mm larger just to get me some assembly allowance but that is just a convenience
    I think one of your worries is whether the Chinese spindle will drill holes in this size due to limited torque. Well because the drills are small you can spin them quickly so there are no issues there and I regularly mill 3 mm holes using a twist drill to 15mm depth.
    You need to watch the flutes blocking after about 10mm so need to do small pecks and wipe the bit with an oiled brush each time it comes out of the hole between pecks. If it welds in the hole it will snap off and ruin your day.
    Are these shoulder bolts? If so you can ream them after drilling to register on the shoulder.
  9. #7
    Chaz's Avatar
    Ye, just clearance for bolts and agreed, 4mm should work too. Ill do very slight pecks and take my time with the drilling.
  10. #8
    Chaz's Avatar
    Sure, thanks, happy to pay.
  11. I have 4mm endmill length 22mm.
  12. #10
    Chaz's Avatar
    Quote Originally Posted by cncmachineokk View Post
    Where did you get these from?
  1. just how deep does a water trough need to be?
    By nobby in forum Plasma Table Machines
    Last Post: 09-07-2017, 04:27 PM
  2. foam cnc carver- deep z axis - 4x4 bed
    By marbles in forum Hotwire Cutting Machines
    Last Post: 17-05-2016, 09:20 AM
  3. What tooling to drill lots of 10mm holes 45mm deep?
    By AlanMJackson in forum Tool & Tooling Technology
    Last Post: 13-01-2014, 08:53 PM
  4. How deep can i cut MDF?
    By MrWiz73 in forum Machine Discussion
    Last Post: 24-08-2011, 10:38 PM
