  1. #25
    Hi Chaz,
    If it helps - in the line boring video I posted recently you can see 3 mm holes being peck drilled (with full retract to clear the chip) at ~12,000 rpm. Can't remember the feed - maybe 300 mm/min? Drill bit is plain HSS.
    You can see the chip fly out each time, and a dab of oil keeps it running smoothly. Starts at 0:32
    https://www.youtube.com/watch?v=sYhDtuqzf2I&t=6s
    Been using this method for some time and it works well.
  2. The Following User Says Thank You to routercnc For This Useful Post:
  1. just how deep does a water trough need to be?
    By nobby in forum Plasma Table Machines
    Last Post: 09-07-2017, 04:27 PM
  2. foam cnc carver- deep z axis - 4x4 bed
    By marbles in forum Hotwire Cutting Machines
    Last Post: 17-05-2016, 09:20 AM
  3. What tooling to drill lots of 10mm holes 45mm deep?
    By AlanMJackson in forum Tool & Tooling Technology
    Last Post: 13-01-2014, 08:53 PM
  4. How deep can i cut MDF?
    By MrWiz73 in forum Machine Discussion
    Last Post: 24-08-2011, 10:38 PM
