Page 6 of 7 FirstFirst ... 4567 LastLast
  1. #51
    Ok - I thought I would put some closure in here..... The random X and Z axis ' jams' were 100% due to electrical interference from the spindle control wires.
    I had unshielded control cable, with shieleded stepper cable
    Then I tried shielded control cable but mistakingly placed the machine earth inside the Spindle power cord, and in doing so charged the entire machine up with a generated AC signal.
    Then I earthed the frame + spindle + spindle shielding + stepper motor shielding seperately to house earth, and finally, no issues !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. #52
    Quote Originally Posted by dachopper View Post
    Motors are NEMA23 381oz/in 3.5A Single Shaft Stepper Motor KL23H2100-35-4A, 0.9 degree.
    Power supply is PS-10N68 - 1000W 68V Power Supply running 4 of the above steppers, ( two of the motors would have been on 50% current hold ) when the other motor stalled also.
    Nema23 running on 68V???
  3. #53
    Quote Originally Posted by dazp1976 View Post
    Nothing wrong with that. Most of us run NEMA23 size motors on about 68V. More volts, better performance. The motors are happy enough - mine have been running like that for about 7 years now. As long as your driver can take it (and again, that's why a lot of us use 80V drivers) there's no problem. Just tweak the max current settings on the drivers so that the motors don't overheat.
    Somewhere there is a guideline formula (originally from the Gecko people, I believe) that suggests that around 50V is the optimum. Firstly, this is a guideline and not a hard-and-fast rule, and secondly, it's wrong anyway. Go by other people's experience!
  4. #54
    Agree. My steppers have been running at 68V on 80V drivers for several years too.
  5. #55
    If I'd figured that out before, I'd have got the 570oz nema23 on 60v for the AMAT25 rather than the nema34 on 60v I have.
  6. #56
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    It's not that simple.
    A 450oz Nema 34 rated at 6 amps will usually easily outperform a 570oz Nema 23 rated at 5 amps.
    Inductance plays a large role. And typically, smaller nema 34 low inductance motors can spin much faster than large Nema 23 motors.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  7. #57
    Horses for courses and You've got the right motors and voltage for that machine. Routers are a different animal so extra torque higher up speed curve helps.
  8. #58
    Lives in East Lothian, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,989. Received thanks 373 times, giving thanks to others 9 times.
    Ger, I think you got your motor sizes mixed up there...
  9. #59
    Bloody hell Dean where have you been Nice to see you back
  10. #60
    Got to get back on the horse some time Clive.
  1. Help with Problem X axis Stepper Please
    By howser37 in forum Gantry/Router Machines & Building
    Last Post: 09-02-2017, 06:31 PM
  2. Which single stepper for long axis?
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 24-05-2015, 08:39 AM
  3. Connecting BOB one axis to 2 stepper drivers
    By Noplace in forum General Electronics
    Last Post: 10-02-2015, 11:56 AM
  4. Z axis error woes
    Last Post: 18-02-2012, 03:07 PM
  5. The dreaded task of workshop tidying!
    By m_c in forum Milling Machines, Builds & Conversions
    Last Post: 26-03-2011, 08:07 PM
