11-08-2017 #1Personally I would just earth the main frame not the Z block ( if you want to earth the Z block connect that to the main frame)The VFD spindle/Z axis block is now earthed direct to the star point. ( No other frame earth, just the one on the Z block )
Let us know how you get on.was a little concerned about the cable shielding pushing an AC signal back into the stepper motor shielding, but it seems to be going ok, 40 minutes into a cut now
Still no pics of the control box !!Last edited by Clive S; 11-08-2017 at 12:56 PM.
11-08-2017 #2
11-08-2017 #3
The stepper ground is temporary as I was still trying to troubleshoot
11-08-2017 #4
11-08-2017 #5
10mm x axis skip. I've now moved the vfd braid shield onto a separate ground than the stepper shielding.
If it happens again, I'll move the spindle motor shield onto th
11-08-2017 #6
Guess what.... all skips happening on parallel moves..... ! Strange
11-08-2017 #7
11-08-2017 #8
Help with Problem X axis Stepper Please
By howser37 in forum Gantry/Router Machines & BuildingReplies: 53Last Post: 09-02-2017, 06:31 PM -
Which single stepper for long axis?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 24-05-2015, 08:39 AM -
Connecting BOB one axis to 2 stepper drivers
By Noplace in forum General ElectronicsReplies: 8Last Post: 10-02-2015, 11:56 AM -
Z axis error woes
By HankMcSpank in forum Machine DiscussionReplies: 46Last Post: 18-02-2012, 03:07 PM -
The dreaded task of workshop tidying!
By m_c in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 26-03-2011, 08:07 PM
