24-08-2019 #2Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
24-08-2019 #3
24-08-2019 #4
24-08-2019 #6
26-08-2019 #7
They don't give the speed I was hoping for but that may be down to the resonance I seem to get. It won't help. The inductance for them shows 4.1.
Looking at curves though the torque is equal between the 23 & 34 at 400rpm and over.
The 34 do however give very good acceleration so it's not all bad.
Spindle rpm will likely only allow 600mm/min anyway with 8mm 3flute.
Still an unfinished project.
The machine is more or less built, oil system is in, enclosure has minor snagging issues. Really I just need to finish the coolant system and I'm ready for first chips.
26-08-2019 #8-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
26-08-2019 #9
I did wonder that. These ones:
https://www.ebay.co.uk/itm/German-Sh...72.m2749.l2649
https://www.robotics.org.za/85BYGH450D-008
26-08-2019 #10
Think Those 860ma drives are analog version which are junk and will be holding those motors back massively. Replace with digital and you'll get different machine.
Regards the motors it looks like they could be parallel wired version but the datasheet on web site doesnt match the spec so I'd still be suspicious.? All the 4 wire they show have high inductance.!
Sent from my SM-T580 using TapatalkLast edited by JAZZCNC; 26-08-2019 at 09:53 PM.
Help with Problem X axis Stepper Please
By howser37 in forum Gantry/Router Machines & BuildingReplies: 53Last Post: 09-02-2017, 06:31 PM -
Which single stepper for long axis?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 24-05-2015, 08:39 AM -
Connecting BOB one axis to 2 stepper drivers
By Noplace in forum General ElectronicsReplies: 8Last Post: 10-02-2015, 11:56 AM -
Z axis error woes
By HankMcSpank in forum Machine DiscussionReplies: 46Last Post: 18-02-2012, 03:07 PM -
The dreaded task of workshop tidying!
By m_c in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 26-03-2011, 08:07 PM
