    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    The entire point of the VFD cable screen is to absorb the EMI from the VFD cables, and drain it to earth. Due the VFD cables carrying a fast switching AC signal, an AC signal will be generated in the screen.
    The fact that there is a voltage present, tells me that's it not correctly grounded. And also that connecting it to the machine frame makes things worse, tells me the machine frame isn't grounded correctly. If the screen was correctly grounded, then there should be negligible voltage in it, as it should be getting drained to earth without causing any problems.
    Which brings me back to my earlier question, are you sure your power supply earth is correctly earthed?
    This is what I mentioned several posts back but you make a good point re the anodised stuff so as M_C has said ground each part ie Z plate to gantry to machine frame to Star point
    Ok - I thought I would put some closure in here..... The random X and Z axis ' jams' were 100% due to electrical interference from the spindle control wires.
    I had unshielded control cable, with shieleded stepper cable
    Then I tried shielded control cable but mistakingly placed the machine earth inside the Spindle power cord, and in doing so charged the entire machine up with a generated AC signal.
    Then I earthed the frame + spindle + spindle shielding + stepper motor shielding seperately to house earth, and finally, no issues !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  1. Help with Problem X axis Stepper Please
    By howser37 in forum Gantry/Router Machines & Building
    Last Post: 09-02-2017, 06:31 PM
  2. Which single stepper for long axis?
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 24-05-2015, 08:39 AM
  3. Connecting BOB one axis to 2 stepper drivers
    By Noplace in forum General Electronics
    Last Post: 10-02-2015, 11:56 AM
  4. Z axis error woes
    Last Post: 18-02-2012, 03:07 PM
  5. The dreaded task of workshop tidying!
    By m_c in forum Milling Machines, Builds & Conversions
    Last Post: 26-03-2011, 08:07 PM
