Thread: Quality of the SX2P
27-07-2017 #1
Hi. Our bench drill at work is awful and well overdue an upgrade. I know this is classed as a hobby machine but it will see less use at work than it would in a hobbyists garage I'm sure.
I'd set up a DRO on it for accurate positioning of holes, making actual use of the drill far quicker and easier. Will mainly be used for drilling fixture points in plastic cases and steel and facemilling/flycutting aluminium stock down to size to then go in our Chinese CNC we use for prototyping and one offs and modifying existing components for a job, which is very good in X and Y but awful at holding tolerances in Z and doesn't face well, and possibly finishing passes in pockets where depth tolerance is important.
I'm interested in how gutsy this is for drilling through up to 10mm steel and how accurate it is in the Z. Are the spindle and table square and stay square? Does it flex under load? Would you recommend it as a light use mill/drill?Last edited by Snapper; 27-07-2017 at 09:16 PM.
sieg sx2p cnc conversion
By terry1956 in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 13-12-2016, 10:41 PM -
Sieg SX2P mill received
By AlexTsekenis in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 24-08-2014, 09:27 PM -
Cut quality
By Web Goblin in forum Machine DiscussionReplies: 22Last Post: 06-02-2013, 07:45 PM -
Quality DTI - Manufacturers
By dsc in forum Marketplace DiscussionReplies: 8Last Post: 13-12-2012, 01:34 PM -
CMM Programmer/Quality Engineer
By Excel in forum Opportunities Available & SoughtReplies: 0Last Post: 22-02-2011, 05:57 PM
