    Details
    General Info:
    Hours of use: Mach3 shows a total operating time of 205 hours
    Materials cut: Aluminium, brass, various woods, foams, plastics and more.
    Cutting area: ~700 x 400mm with Z axis of around 90mm. Also an additional 100mm overhang for taller objects at the front.
    Machine construction:
    Components:
    - HIWIN 20mm rails on all axis
    - 1610 dual ball screws on X axis, 1605 single ball screws on Y/Z
    - All ball screws belt driven
    Electrics:
    - 2.2kW Water cooled spindle + Huanyang VFD
    - AM882 digital drives on all axis
    - CSMIO/IP-M motion controller
    - 8.7Nm NEMA 34 on X axis and 3.1Nm NEMA 23's on Y/Z
    Additional:
    - Mach3 license and setup files to suit this machine (laptop not included)
    - Manual valve controlled air blast setup for metal machining (compressor not included)
    - Water cooling setup for spindle
    It's ready to go as a 'plug and play' machine, just requires single phase mains supply and a laptop/PC with an Ethernet port and you're good to go. Here's some pics of the machine:
ID:	22379Click image for larger version.
ID:	22384Click image for larger version.
ID:	22383Click image for larger version.
ID:	22382Click image for larger version.
ID:	22381Click image for larger version.
ID:	22380Click image for larger version.
    And here's some machined examples of some test cut's and 'one off's' which I have photos of:
ID:	22385Click image for larger version.
ID:	22386Click image for larger version.
ID:	22387Click image for larger version.
    Please PM me if interested - it's located in Newcastle. Thanks
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
    By Tom J in forum DIY Router Build Logs
    Last Post: 02-01-2017, 09:32 PM
  4. BUILD LOG: Steel frame cnc router design/build
  5. Steel frame for 8' * 4' cnc bed ?
    By flanagaj in forum Gantry/Router Machines & Building
    Last Post: 18-10-2011, 08:57 PM
