    Hello There
    It took me 3month to build cnc router
    I am wondering where did missed
    My specs are as follows
    Working area:4*8 feet
    Actuation:TBI ball screws 3210 2510 and 1610 for xyz axis respectively And hiwin linear guide and bearing.
    Stepper motor: 1200oz-in (4.5 amp & 70v) and drive are of 6 amps 80v ac )
    Power supply: i have provided 80v and 6amp to each stepper /driver.
    I am running my cnc router 6mtr/m
    Successfully when drives is set on 6amp
    My stepper motor heats like hell
    When i reduce current my max speed also get reduced.
    Recently my friend showed broucher of some company.
    Company is claiming that max speed will be 25mtr/m that seriously gives me an anxiety. This is hard to believe where did i missed. Why i cant achieve this speed.
    And one more thing is that they are using rack and pinion.
    How this is possible.
    My steppers stalls whenever i try to go above 6mtr/m
    Sent from my Redmi Note 3 using Tapatalk
  2. It will be rack and pinion, you can't get that speed with ball screws on a machine this size, unless you have ballscrew with a high lead and large diameter.
    Quote Originally Posted by kmeshal9 View Post
    Hello There
    Thanks 4 replying After looking for day
    I get it
    I am planning to replace my
    My ball screws with ball screws with pitch 25 or 30.
  4. Quote Originally Posted by kmeshal9 View Post
    I get it
    The higher the pitch of ballscrew the lower the resolution accuracy there's no such thing as a free lunch.
    Or you could use rotating nuts on a xx10 screw as the one you have
    Anyway, what you are missing is that the company you are comparing to uses Servo motors, not steppers. you also do not state how heavy is your gantry. Also nowhere the acceleration is stated. And that could mean a lot. One thing is sure- you can not achieve real life cutting speed as this with stepper motors in any way and accuracy at the same time.
    For your reference i move my 200kg gantry with acceleration 3000mms2 20m/min 2x400W AC servos 230V and 2 rotating ball nuts on 2510 screw. I can hit even 30m/min as my motors can spin faster than 3000rpm up to 5000. Your steppers are good to much lower speed , you probably need to drive them harder with better PSu at higher voltage and so on. So don't compare your machine with an overbuild commercial machine where they simply put some serious servos which are driven at 230V
    PS. Machining at high speeds especially more than 10m/min and Hi Speed toolpaths makes that nuts and screw heat very seriously. You must make sure all is perfectly clean and greased properly
  6. its not just the speed of the motors, its also the critical speed of the ballscrew.
    a 25mm diameter ballscrew that is 2000mm long and using a rotating nut has a critical speed of about 1400 RPM.
    There is a critical speed calculator on our site in this link.
    http://www.zappautomation.co.uk/inde...lculators.html
    However motor speed is clearly enabling you to get a higher speed, but by pushing the screws too much, you could damage the screws.
    Alos remember, that a servo system has a much higher resolution than a stepper system, so if using servos, you can use a higher lead and not loose out too much on the overall resolution, and then spin the screw rather than the nut.
    Also consider the application, may not need a high resolution, if used for wood, thats why a lot of commercial machines like routers and plasma and water cutting machines use rack.
  7. The Following User Says Thank You to Gary For This Useful Post:
  8. #7
    I agree, but now that he has the screws to change them with rack seems a big waste to me.
  1. Running 4 1605 screws
    By kev20009 in forum Lead Screws, Nuts & Supports
    Last Post: 22-02-2017, 10:33 PM
  2. Getting my Arburg c4 up and running
    By deadmeat30 in forum Moulding Machines
    Last Post: 30-11-2015, 09:54 PM
  3. TCT Router cutters in a mill running at 4000 RPM
    By suesi34e in forum Tool & Tooling Technology
    Last Post: 26-02-2014, 08:02 PM
  4. Running a three phase router/mill on a generator?
    By gavztheouch in forum General Electronics
    Last Post: 19-02-2013, 12:39 PM
  5. Running costs of CNC machines?
    By .kyle in forum General Discussion
    Last Post: 19-05-2011, 08:05 PM
