31-07-2017 #10you will have to make sure the baud rate is the same at both ends also start and stop bits are correct, the handshaking might be xon/xoff (ie software handshaking). You might also have to swap pins 2 and 3 over at one end this depends if the Pc is setup as DTE or DCE. one good thing about the com port is that it is hard to breakI do have a PC with a RS-232 port and have tried connecting with that, but I didn't check any of the settings. I'll check the cable too.
Breakout board to Telemechanique Altivar 18 wiring (Mach3)
By Agathon in forum Motor Drivers & ControllersReplies: 14Last Post: 08-07-2017, 07:12 PM -
which breakout board?
By johngoodrich in forum General ElectronicsReplies: 4Last Post: 12-03-2017, 01:54 AM -
FOR SALE: 3 Axis CNC USB Motion Card Mach3 200KHz Breakout Board For Stepper/Servo Driver
By dudz in forum Items For SaleReplies: 0Last Post: 03-01-2015, 03:40 PM -
eBay: UIM2901-5A Mach3 breakout board with spindle speed control
By Fivetide in forum Items On eBay UKReplies: 0Last Post: 05-02-2013, 07:25 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM
