you need to keep on eliminating reasons and i can tell you straight away that i would never use USB-RS232 converter for connecting to servos, or anything. . You need a normal. PC with a normal PCI port and an adapter there. Or even better, a PC with a com port that you could control from bios.
Standard RS-232C RS-422A
specifications
Communications
method
Asynchronous (ASYNC)
Baud rate 2,400 bps
Start bits 1 bit
Data 8 bits
Parity None
Stop bits 1 bit
That above is from your servo drive manual. If baud rate is not set at Com port same same, communication will NOT ever happen
And most of all check that manual https://www.fa.omron.com.cn/data_pdf...8d-u.pdf?id=68 for the proper connection to the drives from the PC side . Check your cabling if is right.
So in other words from page 1-7 seems you need Null Modem Cable https://www.decisivetactics.com/supp...h-serial-cable
Name:	servo omron rs232.PNG
Looking at that drawing and the info you've sent on null modem cables, it's not a straight RS232 cross-over as it's computer pin 2 to driver pin 2 and computer 3 to driver 4. I'll have to make a cable.
Will post and let you know how I get on - thanks again.
