Hi I had KJN cut and drill my frame (With counterboring) which is a little cheaper than using the corners but also stronger. They will do it to your cad model, you could still use corners as well for extra strength.
Cost me £35 +vat for 18 holes with counterboring.
I already had the corners I did it for strength, I used m12 50mm A2 socket bolts.
A top tip if you do what I did make sure you get some corners then use them to get the extrusion straight before putting the bolt in when it's tight you can remove the corner and reuse.
Also 9045 extrusion takes M12!!!Last edited by Desertboy; 07-08-2017 at 06:21 PM.
08-08-2017 #2
I see, i also had this answer in another thread, a couple of the guys thought that it should be fine as long as there are no major crashes and i have a method for adjusting the gantry to be tram.
That's a good shout, i will be buying my Extrusion from KJN too, i have used them in the past! Are brackets alone not rigid enough do you think?
Alex
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
Building a plasma table, need advice.
By superclarkey in forum Plasma Table MachinesReplies: 37Last Post: 20-09-2016, 04:57 PM -
NEW MEMBER: Newbie seeking CNC info for guitar building
By rusty999 in forum New Member IntroductionsReplies: 4Last Post: 15-01-2016, 02:26 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM
