Quote Originally Posted by AlexDoran View Post
Ok, i need to do some serious research to see if that controller can handle that, i know it provides for 4 Axis but im not sure if the 4th can be setup as Dual Axis.
So i know i keep banging on about the weight distribution of the Gantry, but i really am being stupid today. It seems at some point i had lost all of the material properties for my assembly parts, ive just spent a little while going through and properly setting the weights of each component, i have based the Aluminium Plates on being a 6061 Alloy, whether or not this will be the material the plates are cut from i dont know, but it was the most common material so i though i would go with that, i re rain the analysis and it has given me a hopefully accurate Centre of Mass for the gantry, indicated by the Red Dot, im hoping this is a pretty acceptable balance and wont cause any undue wear or stress to the linear bearings:
Name:	COM Final.png
Alex
I'm sorry to inform you that the fourth axis on the controller is only rotational and can't be slaved. Have been drooling over it myself but have to go another way as I'm using 2 motors for my X axis. Boyan runs it with two drivers on the same signal but because of that he lost the ability to home separately.
