13-09-2017 #61
So electronics wise, i have:
4nm Nema 23's
Leadshine AM882 Drivers
DDCSV1.1 Controller
2 x 600Watt 68v PSU's
1 x 23Watt 24v PSU (for the DDCSV1.1)
2.2kw Water Cooled Spindle & Huanyang VFD
Will be using Mechanical Endstops / Microswitches
Had forum member Leadhead pop down today which was great, he had some great tips and recommendations on the build, especially the Nema mounts he suggested which will drastically improve how well they perform (no twisting when stepping).
Got some more bits to sort out but carrying on dry assembling and finding tweaks.
Also gearing up to get this done with the controller:
https://www.youtube.com/watch?v=0ivxcOnEBBM
AlexLast edited by AlexDoran; 13-09-2017 at 10:08 PM.
18-09-2017 #62
Made some progress on the electronics enclosure over the weekend, few people have already mentioned about cooling and moving the VFD out, i got some methods to try and reduce EFI and there will be ~4 fans in the case for cooling.
Starting to think about my wiring in general, how would it be best to run my Nema23's in Bipolar Parallel or Series? Considering i have 68v PSU's? Also, can anyone point me in the right direction of the name of the 8 pin twist a lock connectors i see commonly used?
Alex
18-09-2017 #63http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
18-09-2017 #64Bipolar Parallel is the way.Starting to think about my wiring in general, how would it be best to run my Nema23's in Bipolar Parallel or Series? Considering i have 68v PSU's?..Clive
The Following 2 Users Say Thank You to Clive S For This Useful Post:
18-09-2017 #65http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
18-09-2017 #66
18-09-2017 #67
Motors has 8 or 4 cables, I miss that.
18-09-2017 #68
The motors have 8 cables, is there a way to wire in parallel whilst only trailing 4 core wire back to the driver??
Alex
18-09-2017 #69
Yes, that's how it's usually done. Bring the 8 wires into some kind of junction box with a four-core cable coming out and going to the control box. You can hard-wire the four-core into the control box or use an appropriate plug and socket. I use XLR latching connectors but there are others. My "junction boxes" are 3D-printed (cheaper than small plastic boxes from Maplin) with choc block inside but as long as the cables are securely joined and protected, use what suits you.
19-09-2017 #70
http://www.screwfix.com/p/debox-in-l...ctor-box/8692h
From the manual
http://www.leadshine.com/UploadFile/Down/AM882m.pdf
Mine never came with a manual but I bought 2nd hand AM882's.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
Building a plasma table, need advice.
By superclarkey in forum Plasma Table MachinesReplies: 37Last Post: 20-09-2016, 04:57 PM -
NEW MEMBER: Newbie seeking CNC info for guitar building
By rusty999 in forum New Member IntroductionsReplies: 4Last Post: 15-01-2016, 02:26 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM
