07-08-2017 #11If you are using two screws and two motors you will have to use two home switches to make sure the gantry is put square every time you home.I am not sure about the independent homing, i will need to check that for sure, is this common practise for machines with multiple screws on one axis? Is this to ensure they stay parallel
You can of course use two screws with one motor and a belt driving both screws then one home switch will be fine.
The choice is yours as there are pro's and con's and much debate between the two types.Last edited by Clive S; 07-08-2017 at 02:58 PM.
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
Building a plasma table, need advice.
By superclarkey in forum Plasma Table MachinesReplies: 37Last Post: 20-09-2016, 04:57 PM -
NEW MEMBER: Newbie seeking CNC info for guitar building
By rusty999 in forum New Member IntroductionsReplies: 4Last Post: 15-01-2016, 02:26 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM
