  1. #15
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    If you look at the geometry of the Z plates and imagine both ways of positioning rails and bearings, you will see that you get better support of the moving plate through its full travel if you put the bearing carriages on the fixed plate. It feels wrong at first, but it's the right thing to do! The rails also provide a slight stiffening effect on the moving plate as well, although if you use the usual 20mm plate, that's not going to matter much.
  2. The Following User Says Thank You to Neale For This Useful Post:
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 22-01-2021, 06:54 PM
  2. NEW MEMBER: new member building a cnc router
  3. Building a plasma table, need advice.
    By superclarkey in forum Plasma Table Machines
    Last Post: 20-09-2016, 04:57 PM
  4. NEW MEMBER: Newbie seeking CNC info for guitar building
    By rusty999 in forum New Member Introductions
    Last Post: 15-01-2016, 02:26 PM
  5. Building a hybrid CNC mill. Need advice and recommendations
