04-08-2017 #6
I set Aspire to profile cut a 400mm square at 100mm/s and timed how long it took to mock cut out the full 1600mm. This took 51.40 seconds. So at 30.9mm/s actual speed, clearly not the 100mm/s set in Aspire. The spindle speed is not set in Aspire but on the actual spindle.
I tried the test again using a faster speed but it gave exactly the same time to travel 1600mm. So it must be that motor tune setting are incorrect or inhibiting speed.
My config settings are 26 stesp- 2000 velocity - 1000 acceleration
(As as side note I recalibrated X and Y axis so they are scaled correctly).
lets say as a rule of thumb I wish to cut out 12mm plyood in forms less that A4 scale with a mixture of straight corner and curved shapes, 10mm slots and 8mm holes etc. So reasonable detail.
I'm a little bit stumped why I couldnt change its speed in Aspire and why 100mm/s does not translate to its actual speed. I'm missing something basic am I not ha!
Any ideas welcome
This is the gcode file.
( Profile 1600mm test )
( File created: Friday, August 04, 2017 - 09:52 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 410.000, Y= 410.000, Z= 4.000)
(Toolpaths used in this file:)
(Profile 1)
(Tools used in this file: )
(1 = End Mill {3 mm})
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T1M06
N130 (End Mill {3 mm})
N140G00G43Z20.000H1
N150S20000M03
N160(Toolpath:- Profile 1)
N170()
N180G94
N190X0.000Y0.000F6000.0
N200G00X4.620Y4.260Z6.000
N210G1Z-0.500F600.0
N220G2X3.120Y5.760I0.000J1.500F6000.0
N230G1Y405.760
N240G2X4.620Y407.260I1.500J0.000
N250G1X404.620
N260G2X406.120Y405.760I0.000J-1.500
N270G1Y5.760
N280G2X404.620Y4.260I-1.500J0.000
N290G1X4.620
N300G00Z6.000
N310G00Z20.000
N320G00X0.000Y0.000
N330M09
N340M30
Help with speeds/feeds please?
By examorph in forum Tool & Tooling TechnologyReplies: 5Last Post: 29-01-2017, 01:54 PM -
Speeds and feeds
By eurikain in forum Workshop & EquipmentReplies: 3Last Post: 26-03-2016, 06:00 PM -
Feeds and speeds software?
By Leadhead in forum Computer SoftwareReplies: 9Last Post: 31-10-2015, 09:34 PM -
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM
