Page 2 of 2 FirstFirst 12
    Seem to be getting somewhere with the 12mm ply cutting after carrying out everyone's suggestions + tightening a slightly slack gantry. Thanks for everyone's help.
    Feed 20mm/s
    Speed 15,000rpm
    3mm, two flute up cutter on 2mm deep passes
    Mach3: Velocity 2500 and acceleration 500
    I'm not getting the F/S issue of cutting corners i had before and neither is the cutter or timber burnt.
    I am however still getting a furry edge, the block of wood was lightly sanded to get rid of the burr edge so they are not so prominent in this image.
    I'm going to invest in a 3.175mm down cut and compression cutter to see where those results take me. At the moment i'm only intending to cut smaller parts and perhaps some cabinet doors at a later stage when I upgrade the gantry and whole machine to R&P.
    To get rid of the fuzzy top edge, use a downcut bit, and do NOT climb cut.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  3. The Following User Says Thank You to Ger21 For This Useful Post:
  1. Help with speeds/feeds please?
    By examorph in forum Tool & Tooling Technology
    Last Post: 29-01-2017, 01:54 PM
  2. Speeds and feeds
    By eurikain in forum Workshop & Equipment
    Last Post: 26-03-2016, 06:00 PM
  3. Feeds and speeds software?
    By Leadhead in forum Computer Software
    Last Post: 31-10-2015, 09:34 PM
  4. Feeds and speeds
    By dudz in forum Tool & Tooling Technology
    Last Post: 26-08-2013, 11:42 AM
  5. Speeds and Feeds
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 20-09-2012, 01:38 PM
