Thread: Foam XL hot wire cutter
14-09-2017 #33
What would you cut at 6meter length? i mean, arent all foam blocks 2mters long?
if i was going to make such a serious machine i would have probably used belt on belt drive which will again simplify things. In that scenario there is no need of very big size belt as the stretch is "none"
DIY Plunge Foam heat wire cutting
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 7Last Post: 07-07-2017, 09:37 PM -
Hot Foam cutter for RC aircraft
By rckeith in forum Hotwire Cutting MachinesReplies: 25Last Post: 10-08-2015, 08:32 AM -
BUILD LOG: CNC Hotwire 4 axis foam cutter
By Skipsoaring in forum Hotwire Cutting MachinesReplies: 16Last Post: 29-07-2015, 04:26 PM -
CNC Hot Wire Foam Cutters
By HotwireCutter in forum Manufacturer NewsReplies: 0Last Post: 02-05-2012, 09:04 PM -
NEW MEMBER: First post - want to build a cnc hot wire foam cutter
By rckeith in forum New Member IntroductionsReplies: 8Last Post: 12-12-2010, 12:23 AM
