  1. WARNING
    Before anyone uses this information, sent from the Chinese supplier of my machine, I suggest that you find out what d (p) code 32 means. I have a nasty suspicion that it will lock up the spindle both in PC and manual control.
    I assume there is also a d (p) unlock code, but I'm not going to do something I regret.
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by KeithElcomb View Post
    WARNING
    Why do you have that suspicion? If you do not know then don't use it as a scare for other people.
    The vid you linked to seem to be for a 2.2kw vfd and the setting may or not be the same as the for the 800W spindle.
    PD13 is the general factory reset. But not a good idea to use it unless you know what you are doing.
    Can you say what is the exact problem you have and it would be a good idea to start a separate thread or use your other thread, as this thread was started by Zoprano
  3. Actually Clive, I believe my comments applicable to anyone thinking of buying a Chinese CNC machine.
    Fortunately a very kind member tracked me down and gave me a telephone call. Following his call and setting up my own machine to his instructions, had me up and running very quickly. Had I just followed the video instructions from my Chinese supplier, would have left me with a dead spindle motor, on both manual and PC control. E code LU
    I doubt you have actually ever visited the Jinan Blue Elephant CNC Machinery Co., Ltd. factory in Shandong? Which is relevant to Zoprano's thread. Well, I have in 2015 and can vouch that they are first class people.
    Having said that I will bow out of this thread.
    I also doubt any other member has as well. So if you have been there and have first hand knowledge how come you did not part with it to the OP. A forum is a two way process.
  5. Can we bring these ping pong posts to a conclusion please and move on.
  6. I have bought a cheap Chinese machine and currently in the process of putting it right. The controller was buggered from the word go, the seller kindly refunded me more than what the controller was worth which I was grateful for. Most of the parts the machine was put together with are fine so far, I have however replaced the motor cables with shielded ones and also purchased a new controller box and software from planet cnc. Not got the machine up and running yet due to time and adding additional parts such as more powerful spindle, limit switches and the actual wiring.
    A lot of people slate these machines but at the end of the day I guess you get what you pay for, hopefully I will be able to get the machine up and running in the next few weeks so keep an eye out on my build thread, I will report back onto this thread also with my progress but I do have faith in my little machine :-)
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
    A friend bought a Chinese machine for his small business - Acctek 6090. The quality of paint finish was poor, the machining was accurate enough but with a poor finish. A lot of holes looked as if they were drilled with a handheld drill, and the "target" for one of the limit switches (inductive proximity) was the shank of a broken tap, which also needed adjusting. It came with a Mach3 demo licence. Took a day or two to unpack, adjust, and generally configure but it is now a useful and profitable machine. My friend bought a real Mach3 licence (for which he had budgeted) and also arranged his own transport which was cheaper and better than the manufacturer's offer. For the price, a good machine. There may be an element of luck in this, but as long as you accept that what you get is slightly closer to a kit of parts than a ready-to-go machine, it can be a cost-effective way forwards. I wouldn't buy one because I like building stuff myself, but my friend probably paid not much more than I spent buying bits for a slightly larger machine and saved himself a lot of work (which is important for someone who is using the machine to earn money). A year later, he is still happy with it.
  1. Replacing Chinese screws/nuts with British bought gear.
    By Wal in forum Lead Screws, Nuts & Supports
    Last Post: 15-11-2014, 11:30 PM
  2. Anyone ever bought a Router from China? (not ebay ones)
    By sly666 in forum Marketplace Discussion
    Last Post: 03-11-2012, 10:45 AM
  3. One of those shops you're glad are still around.
    By Peter. in forum General Discussion
    Last Post: 15-10-2012, 01:24 PM
  4. Finally bought a CNC router!
    By tumutbound in forum Machine Discussion
    Last Post: 15-12-2011, 10:15 PM
