  1. #8
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by KeithElcomb View Post
    WARNING
    Before anyone uses this information, sent from the Chinese supplier of my machine, I suggest that you find out what d (p) code 32 means. I have a nasty suspicion that it will lock up the spindle both in PC and manual control.
    I assume there is also a d (p) unlock code, but I'm not going to do something I regret.
    Why do you have that suspicion? If you do not know then don't use it as a scare for other people.
    The vid you linked to seem to be for a 2.2kw vfd and the setting may or not be the same as the for the 800W spindle.
    PD13 is the general factory reset. But not a good idea to use it unless you know what you are doing.
    Can you say what is the exact problem you have and it would be a good idea to start a separate thread or use your other thread, as this thread was started by Zoprano
  1. Replacing Chinese screws/nuts with British bought gear.
    By Wal in forum Lead Screws, Nuts & Supports
    Last Post: 15-11-2014, 11:30 PM
  2. Anyone ever bought a Router from China? (not ebay ones)
    By sly666 in forum Marketplace Discussion
    Last Post: 03-11-2012, 10:45 AM
  3. One of those shops you're glad are still around.
    By Peter. in forum General Discussion
    Last Post: 15-10-2012, 01:24 PM
  4. Finally bought a CNC router!
    By tumutbound in forum Machine Discussion
    Last Post: 15-12-2011, 10:15 PM
