12-08-2009 #5
It's a good news, bad news answer.
First off you only need 3 inputs if you want to keep them separate which is a good idea.
If you are using Roy's Uniport board stuff the e-stop into pin 10 input 1.
don't link them as Roy shows in his manual.
Linking will work but they will only work as limits.
Bad news is Mach sees both switches on one axis as just a limit, it can't differentiate between the two.
this is a problem with Mach that I have been trying to get altered for ages but Brian just don't seem interested. The new mach4 is supposed to be able to see both switches so it may filter down into Mach3 ?
If you hit a limit switch it knows but not which one so it's possible to jog further onto the switch. Knowing which one would allow you to only jog off and not further on.
Good news is it can use one switch as a home [ that's the annoying bit in Mach, it know which switch is the home but not limit plus or minus ????? ]
This is why you need 3 inputs, two switches daisy chained for X,Y and Z input into pins 11,12 and 13, inputs 2,3 and 4 on Roys board.
Then go into config > ports and pins> input signals and tick them all down to Z home.
Set the port number to 1 and all the pin numbers on X to 11, Y to 12 and Z to 13.
that sets limits up.
Then go to Config > homing> and use home neg to set which switch you want to home at. Ticked is one switch, cross is the other.
PS Done with my bits yet ?John S -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
Limit and Home Switch Choice
By Wobblycogs in forum General ElectronicsReplies: 25Last Post: 02-12-2013, 06:16 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch Cable ...
By Wobblybootie in forum General ElectronicsReplies: 3Last Post: 17-01-2011, 04:37 PM -
limit switch connector options?
By routercnc in forum General ElectronicsReplies: 5Last Post: 04-09-2010, 02:11 PM
