  1. #41
    I'll have a gander and check it out I've worked out this is running enough when on 0 amps to anodise how I want at 2.5 hours for smaller parts
    Sent from my SM-G960F using Tapatalk
  2. #42
    Couple more bits rattled off getting some consistency now I've got the mounting to the rack setup rite. Have to say this power supply ain't bad tbh. I've ordered a small 30 w 5 amp unit off the bay that's reviewed well as a permanent fixture for the smaller setup as the fusion units coming to the big boy tank. All my amp issues were purely down to how I was attaching the parts ( not enough contact ) in the end ally mig wire 0.8mm wound into coils and pushed tight into the holes has worked perfectly for what I'm doing
  3. #43
    I was attaching my parts using 1mm titanium wire , drill in part somewhere where is not seen 1mm hole and using pliers push the wire. Never had contact problems. I believe it's one of the best way to avoid contact problems when anodizing
    I've started using 0.8 mig wire and making coils into holes or make a big coil inside the tube since then I've had no issues
  5. #45
    Does anyone have a rough estimate for pH ideals of electrolyte solution ? I've read between 1 and 2 but getting 0 on my meter
There are currently 693 users browsing this thread. (0 members and 693 guests)
  1. Power supply
    By racerbear02 in forum Laser Machines & Building
    Last Post: 13-09-2015, 09:27 AM
  2. FOR SALE: power supply
    By Web Goblin in forum Items For Sale
    Last Post: 14-09-2014, 03:19 PM
  3. Replies: 0
  4. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 11:01 PM
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 10:27 AM
