    It's very odd, Im unable to get amps to push any higher then 0.3/0.5 amps when anything aluminium is placed into the tank using it, I'm using an aluminium half inc unf adapter which has the positive directly connected to a (sanded) bare patch of aluminium as has the part I'm wanting to do which is half inch unf female threaded onto the part that's positive. I'm unsure where the issue lies or if the supply is faulty perhaps ?
    Sent from my SM-G960F using Tapatalk
    Hmmm, sounds odd - maybe post a pic of your bath and then perhaps someone can spot the problem?. BTW, how big is the part you're trying to anodise??? If it's small the current will be low anyway at 15V.
  3. The Following User Says Thank You to Voicecoil For This Useful Post:
    Will do once I finish work, much appreciated the part is roughly 31 sq inches
  5. #4
    Check at the back if there are any jumpers. My power supply has jumpers that change the mode of it, so that may be the reason. Use thick wires and clean your plates. What plates are you using inside the bath? Aluminum or lead?
  6. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  1. Power supply
    By racerbear02 in forum Laser Machines & Building
    Last Post: 13-09-2015, 09:27 AM
  2. FOR SALE: power supply
    Last Post: 14-09-2014, 03:19 PM
  3. Replies: 0
  4. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 11:01 PM
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 10:27 AM
