Thread: Power supply for anodising?
The constant current is to limit as i said to a certain current the current draw. Then current starts to drop at a certain time, when certain thickness is achieved, hence you can judge the thickness by the current draw. You can not give more current than it could take when there is the anodizing layer already formed
I don't know how big you are going to make your tank but here is some friendly advice:
1. Dont be cheap on the container and if possible buy proper anodizing container. make sure it's from the right plastic. And keep the rest in dark place inside.
I used a plastic one from chinese shop which i deemed good at the time and it worked well. In fact i bought 2 of them , transparent, and one was fit inside the other as extra security.
That did not stop the original 20l plastic container to brake in my hands half full with acid when i was moving house next year and 10l of acid to fall and splash from 1 meter around me. Luckily my reaction was fast and as i always use full face protector , working trousers and protective boots around acids and when welding, so i got without a scratch. The plastic have deteriorated which is very strange, but i think that was result from me leaving it outside, though it was covered. The chinese transparent boxes were ok though
2. Junkyard is your best place to go and find aluminum sheet. Any sheet will work. I used 1mm sheet with great results. If anodized, just use the other type of acid that you will use for cleaning your pieces to wash away the anodizing. Do the tank properly and use aeration, temp monitoring. If you do the tank big enough there will be no need for temp control, though if you are serious enough its not a big deal to DIY a way to cool the tank. No need to say that you must heat it using fish tank heater to the proper temperature.
3. If there is a way to do all that outside open air beneath a shelter or sth, that's the best way. It stinks and is dangerous for health. I wear respirator with proper filter / which is different from normal painting filter/ . Maybe you know summer here in Spain, every time i was anodizing i was dressed like a nuclear response team, sweating like a pig, but health is quite more important. My tank was about 70x50x50cm and i dont see how sb will do that inside if there is not an extractor on top of it. Anyway, is best to use an extractor even outside so fumes go somewhere else , hopefully not your neighbours bedroom window
4. Check all that works correctly with water before using actual acid in the tank. Do yourself a favor and buy a water osmosis sytem as you will need a lot of water, so buying distilled water will not do. Even for small projects.
Power supply
By racerbear02 in forum Laser Machines & BuildingReplies: 0Last Post: 13-09-2015, 09:27 AM -
FOR SALE: power supply
By Web Goblin in forum Items For SaleReplies: 0Last Post: 14-09-2014, 03:19 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
