Thread: How do I stop torn fibres
08-08-2017 #1
Guys,
Just getting to grips with my machine and it is finally obeying my instructions.
Please can someone advise me of the possible cause of torn fibres when engraving text. By torn fibres I mean that all round the text the wood is frayed and making it almost impossible to see what the text is. I was using a 90 degree pointed router bit from my normal router set. Router speed was around 16 - 20000.
Not sure if the bit, speed or both causing this problem, appreciate your thoughts
Tony
08-08-2017 #2
I'm certainly not a wood expert, but some types of wood will be worse than others - what are you cutting?
If using a v-point then it just needs to be as sharp as possible, if using endmills then downcut can be useful for a clean edge assuming you can evacuate the chips effectively.
I assume you've tried just giving it a once over with some fine sand paper to de-burr the edges?
The Following User Says Thank You to Zeeflyboy For This Useful Post:
08-08-2017 #3
09-08-2017 #4
With MDF, the quality of the MDF, and the sharpness of the bit, will make a big difference.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
Syil X4 Plus - E-stop issue
By Keith-h in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 03-12-2016, 05:53 PM -
Exact stop / CV problems
By fvfdrums in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 31-08-2015, 01:27 PM -
Spindle Stop?
By manofgresley in forum Spindles & Drive MotorsReplies: 21Last Post: 08-01-2013, 06:37 PM -
E-STOP Circuit - will this cause any problems?
By birchy in forum General ElectronicsReplies: 34Last Post: 18-12-2012, 04:35 AM -
wiring e-stop button
By deannos in forum General ElectronicsReplies: 10Last Post: 14-01-2012, 11:03 AM
