    Hi All
    In another post regarding a new build, one of the contributors commented:
    If you are using two screws and two motors you will have to use two home switches to make sure the gantry is put square every time you home.
    You can of course use two screws with one motor and a belt driving both screws then one home switch will be fine.
    This might be another example of "the blindingly obvious", but to me it's not......yet!
    This was a moving Y gantry machine.
    If the machine was well designed for maximum rigidity, and accurately built with good quality components (as best this can be achieved in "home" circumstances), why does it go "out of square" such that "squaring" is necessary?
    I can only think that it might be caused by one motor missing a step.......but then why doesn't the gantry resume "squareness" naturally when the system is powered down?
    But this suggests that in a single motor, twin belt drive moving gantry machine, the gantry always remains square?..........does it?
    Then I wonder what is regarded as "square" or unacceptably "out of square"?
    5um/m, 50um/m?
    Can someone explain and put this into perspective for me please.
    Many thanks
    Martin
    If the machine is rigid enough that it can't go out of square you could drive just one side, if it's not rigid enough to drive just one side then it can go out of square and zeroing on one side may not set the machine square.
    The exact figures will depend on the individual build and requirements but why wouldn't you want to make a machine be the best it can be? ;-)
    - Nick
    -Nick
    I WOULD want a machine "the best that it can be". My 40+ years of Engineering has instilled in me the importance, no, necessity of (appropriate) machine precision, accuracy and rigidity.
    I am currently trying to get my head around ALL of the elements of what many you guys have been doing for that long that it is probably second nature.
    So, expanding on what you have said:
    If a machine is not rigid enough such that it needs twin homing squaring, do the belts in the single motor approach keep an adequate squareness?
    Can anybody put um numbers on this?
    - Martin
    Look up belt manufacturers specifications on length change versus temperature and tension and combine that with your pulley diameters and screw pitches to get a number.
    Using a tensioning system which applies equally to two both upper and lower belt runs will almost eliminate errors from temperature and tension, good grade ground ball screws with pre-tensioned ball nuts will help too.
    - Nick
  5. The Following User Says Thank You to magicniner For This Useful Post:
  6. #5
    Thanks Nick
    ..............yes I'll do just that.
  7. #6
    You can get belts with various reinforcements, fabric, more exotic fibres and steel wires which will all perform differently with changes in temperature and tension.
  8. The Following User Says Thank You to magicniner For This Useful Post:
  9. #7
    Lives in Plymouth, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    I have a machine with an approx 1000mm long gantry, driven at each end. Couple of ways in which it can get out of square:
    One motor stalls for some reason, or sometimes when I hit the e-stop button. If the two motors do not stop at the same time, or come to a halt at slightly different rates, you have lost sync.
    When you first power on the stepper drivers, the motors may or may not be at a full-step point. If not, it's likely that the driver will initialize it to the nearest full step, although I believe that some drivers are supposed to remember the last state when powered down. It's possible that if this happens often enough, the gantry may drift slowly out of square, a tiny amount each power-down/power-up cycle.
    Homing both ends to a known position gets round these problems; on my machine it will hold these settings for an entire session unless one of the above happens.
  10. #8
    So Neale
    whether it is motors jumping sync/steps, and/or the movement of a less than stiff gantry/endplate/bearing setup, the TWIN homing switches correct the gantry squareness.
    Makes sense.
    And presumably, within a single motor/twin belt system, the "stiffness" within the drive belt arrangement tends to hold the gantry square.
    Great got it thanks.
    -Martin
  11. #9
    Quote Originally Posted by MartinS View Post
    So Neale
    Makes sense.
    -Martin
    Yes that is correct, but with using one motor you have to use a bigger one like a nema34 which usually requires a bigger volatage to drive it. The single motor setup does not go out of square, and using 2 motors hence the duel switches you also.need stall detection etc in case one drive packs up etc
  12. The Following User Says Thank You to Clive S For This Useful Post:
  13. #10
    Noted Clive, thanks
  1. BUILD LOG: "Henge", 3 Axis Cnc, Fixed Gantry, Moving Table
    Last Post: 20-03-2017, 08:43 PM
  2. "Hacking" and "Modding"
  3. Setting up "System 45" 3 axis unit by DIYCNC
    By StevenT in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 03:22 PM
  4. Setup for squaring twin X-axis gantry
    By routercnc in forum Gantry/Router Machines & Building
    Last Post: 26-03-2014, 11:13 PM
  5. "Racks" VS "ball screw"
