    Hi guys,
    I had to enhance this picture to show the problem as it's actually quite faint. It's not just me, I have noticed it in many other people's finishes, usually when cutting thick pieces. In my case I was cutting (contouring) 15mm plate with an 8mm endmill and it only happens at the start of long pieces, i.e. when the milling machine bed is furthest from its centre, then it soon disappears along the line when the bed starts to travel closer to the centre. What can cause this waviness?
    Second question. Cutting noises: do you have some video link where one can hear what "chatter" actually sounds like?
    I have experienced what I think I would call "resonance", but maybe this is what you call "chatter". For example, when squaring the edge end of 40mm extrusion using a long 12mm endmill, you get this unbearable and continuous high pitch shrill noise that can sometimes be reduced a little by trying different motor revs, usually reducing revs, or increasing feed rate, I think. Similar noise sometimes when parting off on the lathe some distance away from the chuck.
    So if this high frequency noise is what you call chatter, how does it differ from resonance?
    Many thanks.
    Edward
  1. How to get this finish..?
    By Wal in forum Metal Finishing Techniques
    Last Post: 02-02-2017, 11:08 PM
  2. How to get this finish?
    By andy_con in forum Wood Finishing Tips & Tricks
    Last Post: 05-07-2016, 10:53 PM
  3. Smooth finish with v bit on mdf
    By Skydeals in forum General Discussion
    Last Post: 16-10-2015, 10:28 PM
  4. Aluminum finish
    By Boyan Silyavski in forum Metal Finishing Techniques
    Last Post: 07-09-2014, 07:32 PM
  5. Better finish
    By luke11cnc in forum Wood Finishing Tips & Tricks
    Last Post: 27-03-2012, 11:25 PM
