Thread: Wire EDM machine
03-09-2017 #27
I'd guess the clever bit must be in how much power you can feed down that tiny wire without over egging the pudding with Volts and lengthening the spark or over ramping the Amps and melting it. Lots of sparks per second seems to be better than a few fat ones, so you need low inductance and presumably power it from both ends of the wire which sounds tricky 'cause one end is under water and has to reach around the part being cut.
BUILD LOG: Building a Cnc diy wire forming machine
By Jeromep in forum DIY Mill Build LogsReplies: 2Last Post: 25-09-2016, 11:13 PM -
Wire diagram
By Raymond in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 11-06-2014, 06:24 PM -
CNC hot wire cutter
By Nstocks in forum Machine DiscussionReplies: 0Last Post: 22-05-2014, 07:54 PM -
How to Wire this Sensor
By manofgresley in forum General ElectronicsReplies: 1Last Post: 26-11-2013, 05:09 PM -
Wire.. Oh why so many types....
By BedlamRik in forum General ElectronicsReplies: 5Last Post: 05-01-2013, 01:05 AM
