25-08-2018 #191
Oh btw,
I ordered a AMD Rysen 5 2400g based pc for gaming for the kids.
But i will try F360 cad on it, it might be a very cost effective setup.
Will report back on this.
Grtz. Bert.
Edit:
Oh this guys made good work of explaining,
https://youtu.be/HRginJ3c4wM
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 25-08-2018 at 11:47 PM.
26-08-2018 #192
I would probe the work piece each time unless running batches of same parts.
Tools are good to have in cam library it makes collision detection easy, simulation works as well, you will generally need some sort of tool in there or you cant CAM a part.
I have no ATC so my tool numbers can be anywhere but i have my first 8 tools fixed to my most used ones as my tool rack has rows of 8 holes so first row is fixed :)
I use a touch-probe for XYZ detection as well as a tool height probe for tool setting - i have BT30 tool holders so my tool fitting is repeatable and can use the tool table in Mach3 for length offsets.
If using R8 or spindle collets the the tool table will be no use and tool heights will need to be set each time they change.
Its fun :)
The Following User Says Thank You to Davek0974 For This Useful Post:
26-08-2018 #193
If you are making general hobby parts then all sorts of setups are required including vice work, plates clamped to the bed, set against dowel pins etc.
Also are you planning on using epoxy to level the bed? You can skim this with the router to get a surface which is parallel / matches your rails.
27-08-2018 #194
Hi Routercnc,
Ok so a lot of pins and clamp options then :-)
Yes i was thinking of pouring on a surface i can cut parallel to X/Y with the router.
This should become the reference surface.
Maybe gluing on some hpl like trespa is also an option, looks like it is easy to cut as well and equally pressure resistant.
Of course as thin as possible, and then put some strategicly placed 8040 alu pieces in between the crossmembers in the x and y directions for easy adjusting / sliding T nuts.
My crossmembers are spaced about 40 cm appart i have a box filled with 8040 cut of pieces i can do tetris with for this purpose.
It looks like i can still put a sump under the bed then or a part of the bed to stop fluids from raining down to the floor. if i decide to play with spray or flood cooling later.
Also i need to think about the add in vertical bed i have on my wish list.
I did run in to problem yesterday, getting 0-10volt working on the chinese HY02D223B vfd..
P001 = 1
p002 = 2
This did not do the trick yet.
VFD does not start.
M3 S5000,
This clicks my relays and puts 10volt out at the bob.
But no action at the vfd yet.
Manual control does not work now any more.
FOR ; DCM to bob relay,
VI to bob 0-10volt output.
ACM to bob Analog common.
I think ill check the vfd stand alone first.
direct connect vfd 10 volt to VI
and a short
FOR to DCM terminals
I read something on the webs about a J terminal... no such thing...
Also ill read the manual more carefully so to see what i missed. (more then 2 min)
After reading more carefully:
I have to check the values for pd044 through pd049
Maybe some extra functions are enabled.
Grtz Bert.
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 27-08-2018 at 07:26 PM.
27-08-2018 #195
Ok so i solved the FOR DCM problem.
A wiring issue. 8)
Now i need to find out how to control the 5 axis bob 0-10v output.
m3 s1000 turns on relais
m5 off.
S1000 should set a voltage to output pin 1.. in pwm..
Im not sure what pwm speed / frequency works with the bob
1 khz?
Also it looks like it is proportional but reversed.
Anyone got a 5 axis 0-10volt working on uccnc?
Or should i skip hardware I/O and go straight for modbus?
Grtz Bert.
29-08-2018 #196
Ok solved the uccnc vs 5axis bob pwm/0-10volt programming.
My UCCNC settings are:
Pin 1 port 3. (im using port 3 for now)
base frequency 800hz
Looks frequency fixes linearity issues for me
minimum dutycycle 100%.
maximum dutycycle 0%.
This fixed the reversed 0-10volt.
Maybe Ill will adjust settings to make it work from 2-10volts later.
so probebly 80 to 0 duty cycle
I dont like the 0 volt level.
It is almost linear now.
Next is to get HY vfd to react to external 0-10v.
Somehow the dial on the vfd is still active instead of external signal.
Must have still missed something.
Grtz Bert.
31-08-2018 #197
So i finally solved my 0-10 volt to VFD problem.
Some things in the manual are not completely like the vfd in real life.
The terminal vr does not exist.
Missing that one made me search for what i was missing earlier, terminal 1,2,3 J.
After staring puzzled to the vfd for a while i finally saw it, on the right side of the screwterminals
A jumper style selector. After moving the jumper from pin 2-3 to pin 1-2 the frontpanel potmeter did not work but the 0-10volt started working.
Just 1 problem left... only 9.62volt...
So not 24000 rpm but 23200 orso.
After filling up the cooling circuit i gonna try first cut tomorrow i hope.
Grtz Bert.
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 01-09-2018 at 12:08 AM.
The Following User Says Thank You to driftspin For This Useful Post:
11-09-2018 #198
Today i did some rigidity testing.
My findings are Y and Z direction are much stiffer than the X direction.
Because of a design decision to have the x ballscrews near the top of the bed there is a quitte long linkage bar to the ballnut.
In the design is a linkage bar of a 70x5 mm strip 200mm long.
I under estimated the forces a bit.
The strip twists under x direction forces.
One can see the ballscrew flex a little too as a result of the week linkage.
Result is about .4mm of flex at 200n of force when the z is almost fully extended.
About 0.04mm ish at 20n of force.
So the first upgrade is identified before the first part is produced :-)
Grtz Bert.
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 11-09-2018 at 10:09 PM.
13-11-2018 #199
Hi guys!
I am confused and have a few quick questions about uccnc vs fusion360.
Do i need to put my router bits in the tools library in both f 360 and uccnc equally? Like in numbering of the tools and dimensions?
And i am really trying to understand and start using a Z touch probe not sure what default probing routine does... does it change something in relation to G54 position?
My Ztouch probe cycle basically works touching off a plate connected to an input now.
Also am not sure where to entre the Z touchplate thickness offset . Somewhere in the m31 macro maybe?
Grtz. Bert
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 13-11-2018 at 08:46 PM.
02-02-2019 #200
Ok so i figured some stuff out.
Made some (very slow) progress and produced the first parts for my diy dust shoe.
I need to get familliar with F360 modelling and manufacture options contour pocket 2d 3d
Was struggling with some differences between solid works and F360.. Youtube was a great resource.
I am really impressed on accuracy of the machine.
A 120mm circle was off by only -0.02 mm in both directions i actually suspect my cutter dimensions being not accurate.. Not important for now.
For now it is far better then my current operating skills.
I bought an acculock ( kurt style ) vise 140 mm and put grid of m6 nuts in a multiplex spoilboard.
The vise needs a solid support structure i still need to fabricate.
Grtz Bert.
The Following 2 Users Say Thank You to driftspin For This Useful Post:
BUILD LOG: First time build - Steel Frame CNC Router
By examorph in forum DIY Router Build LogsReplies: 144Last Post: 19-10-2023, 06:25 PM -
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
BUILD LOG: Steel frame cnc router design/build
By CraftyGeek in forum DIY Router Build LogsReplies: 110Last Post: 06-05-2015, 10:00 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
BUILD LOG: First steel diy CNC router build
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
